| » Balance Ring clips are gone |
Model Number: 110.20172001 Brand: Kenmore Age: 1 - 5 years
I inherited this Kenmore washer #110.20172001 (it came with the building) Plugged it in and tried to wash a batch. It didn't seem to be spinning fast enough and sure enough, the clothes were still wet afterwards. After closer inspection I found the balancing ring to be detached from the basket. I opened up the machine and found that only three of the eight clips are there. I'm hoping that the ring being loose was slowing down the spin. Is it clip # AP3136071 or must I order the whole ring? Actually that might be worth it since the clips are $4.36 and the ring is $30.82. Should I be looking for other problems here or will getting the ring fastened again fix it? What other parts should I change since I'm in there? Tub gasket?
Thanks in advance... |
| Display Modes | |
| Is it hard to install the tube ring and seal on a washer? | candylee310 | Dishwasher Repair | 3 | 06-20-2008 04:01 PM |
| Tub out of balance | bjdvorak@mwt.net | Washer Repair | 0 | 05-09-2008 12:07 PM |
| off balance | vabshire | Washer Repair | 3 | 04-21-2008 04:21 AM |
| Lost wedding ring | tumble | Dryer Repair | 2 | 03-16-2008 05:57 PM |
| Off balance | BobsAppl | Washer Repair | 0 | 11-30-2007 05:55 PM |
