Discuss
Washer won't spin or drain
 in
Washer Repair
I don't know how old this stacked unit is but it worked great UNTIL the washer wouldn't spin or drain.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't spin or drain
  #1 (permalink)
Old 04-18-2010, 12:25 PM
Junior Member
chefgarden is on a distinguished road
Default Washer won't spin or drain
Model Number: LTE5243DQ3   Brand: Whirlpool   Age: More than 10 years
washer wouldn't spin or drain. I don't know if its worth fixing, or what might be wrong. Can you help ??
Ads By Google
Related Models
Whirlpool LTE5243DQ3
Whirlpool LTE5243DQ4 Washer/dryer Laundry System
Whirlpool LTE5243DQ5 Washer/dryer Laundry System
Whirlpool LTE5243DQ6 Washer/dryer Laundry System
Whirlpool LTE5243DQ7 Washer/dryer Laundry System
Whirlpool LTE5243DT2
Whirlpool LTE5243DT3
Whirlpool LTE5243DT4 Washer/dryer Laundry System
Whirlpool LTE5243DT5 Washer/dryer Laundry System
Whirlpool LTE5243DT6 Washer/dryer Laundry System
Whirlpool LTE5243DT7 Washer/dryer Laundry System
Whirlpool LTE5243DZ0
Whirlpool LTE5243DZ1
Whirlpool LTE5243DZ2
Whirlpool LTE5500W1
Whirlpool LTE6234AN0
Whirlpool LTE6234AN1
Whirlpool LTE6234AN2
Whirlpool LTE6234AN3
Whirlpool LTE6234AW0
Whirlpool LTE6234AW1
Whirlpool LTE6234AW2
Whirlpool LTE6234AW3
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1
Whirlpool LTE6234DQ2
Whirlpool LTE6234DQ3 Washer/dryer Laundry System
Whirlpool LTE6234DQ4 Washer/dryer Laundry System
Whirlpool LTE6234DQ5 Washer/dryer Laundry System
Whirlpool LTE6234DQ6 Washer/dryer Laundry System
Whirlpool LTE6234DT2
Whirlpool LTE6234DT3 Washer/dryer Laundry System
Whirlpool LTE6234DT4 Washer/dryer Laundry System
Whirlpool LTE6234DT5 Washer/dryer Laundry System
Whirlpool LTE6234DT6 Washer/dryer Laundry System
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1
Whirlpool LTE6234DZ2
Whirlpool LTE7245AN0
Whirlpool LTE7245AW0
Whirlpool LTE7800W1
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB Ref - Top Mount
Admiral LTF1812ARW Ref - Top Mount
Admiral LTF1812ARZ Ref - Top Mount
Admiral LTF2112ARB Ref - Top Mount
Admiral LTF2112ARW Ref - Top Mount
Admiral LTF2112ARZ Ref - Top Mount
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
  #2 (permalink)
Old 04-19-2010, 12:05 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
The most common cause is a failed lid switch.
  #3 (permalink)
Old 04-19-2010, 02:27 PM
Junior Member
Default Washer won't spin or drain.
Quote:
Thank you ! How do I access that switch ?
Whirlpool Model LTE5243DQ3
  #4 (permalink)
Old 04-20-2010, 07:36 AM
Senior Expert
APP Volunteer
Default
Here's a parts diagram. the lid switch assembly is part #22 in the drawing.
Washer top and lid replacement parts for WHIRLPOOL LTE5243DQ3 | AppliancePartsPros.com
Part number: AP2947199
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't drain or spin... julietmcclure Washer Repair 4 10-05-2009 07:29 PM
GE Washer won't spin; won't drain graye2 Washer Repair 1 10-02-2009 07:02 PM
my washer doesn't spin or drain monickm Washer Repair 1 04-07-2009 03:11 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
Washer won't drain or spin carrol Washer Repair 2 08-20-2007 06:37 AM
