Discuss
Kenmore washer dial doesn't move
 in
Washer Repair
I have a Kenmore washer model 110.26832692. I bought it in 03 or 04 and then stored it until last
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer dial doesn't move
  #1 (permalink)
Old 04-17-2010, 09:18 PM
Junior Member
RandallFlagg is on a distinguished road
Default Kenmore washer dial doesn't move
Model Number: 110.26832692   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore washer model 110.26832692. I bought it in 03 or 04 and then stored it until last year. It's been working ok, but tonight the dial doesn't advance. I set it for 14 wash and it never advanced to rinse or spin. Can you tell me what I need to look at to repair the unit. Also the machine has a dial for 2 rinse that hasn't worked since new. I never worried about it, but if it's an easy fix I'd like to repair it also. Thanks for any help.
Ads By Google
Related Models
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
Kenmore 110.5807961  KENMORE GAS DRYER
Kenmore 110.5808000  KENMORE ELECTRIC DRYER
Kenmore 110.5808010  KENMORE ELECTRIC DRYER
Kenmore 110.5808100  KENMORE ELECTRIC DRYER
Kenmore 110.5808300  KENMORE ELECTRIC DRYER
Kenmore 110.5808500  KENMORE ELECTRIC DRYER
Kenmore 110.5808700  KENMORE ELECTRIC DRYER
Kenmore 110.5808800  KENMORE ELECTRIC DRYER
Kenmore 110.5808810  KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 04-18-2010, 03:40 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I would try to spray the timer contacts with non-residue contact cleaner available at Radio Shack. Just turn the timer while spraying. If a plastic timer. just spray in by the connector seam.
__________________
  #3 (permalink)
Old 04-30-2010, 06:37 PM
Junior Member
Default
Thanks for the reply Rich. I tried using some no solvent contact cleaner. Behind the dial is sealed. I shot some cleaner on the middle stem and spun it a few times. It didn't work. Do I need to get inside the housing to spray anything. If so it doesn't look like it will be easy to open up the control area. The back is one piece from top to bottom. If you have any more ideas let me know. Thanks
  #4 (permalink)
Old 05-01-2010, 04:03 AM
Senior Expert
APP Volunteer
Default
You must use non-residue contact cleaner, very penetrating. Will clean contacts even when sprayed outside of the timer near the contacts.
__________________
  #5 (permalink)
Old 05-02-2010, 11:30 PM
Junior Member
Default
Rich, I should have typed no residue, not no solvent. Since you state it again, I'll try again. I'm using crc no residue contact cleaner if I remember correctly. Thanks for replying.
  #6 (permalink)
Old 05-03-2010, 01:34 AM
Senior Expert
APP Volunteer
Default
You can also try sticking 115 volts to the timer motor if mounted externally and not contained inside a plastic timer.
__________________
  #7 (permalink)
Old 05-17-2010, 06:44 PM
Junior Member
Default
Hey Rich, thanks for the replies. I tried the contact cleaner again. Still no luck getting it to move. Everything works, just the timer doesn't advance. If I move it the correct action starts. I pulled the dial (knob ) out as far as possible, which isn't much and sprayed the &(*& down the middle shaft. It looks completely encased in white plaste with 2 screws holding it in place. I don't see how any of the cleaner is getting to any contacts. Also don't see how to get 110 to anything. To open it up looks like the entire cabinet has to be removed. I think I opened it up years ago to see why the 2nd rinse controls wasn't working. Anyway, if you have any other suggestions, I'd really like to try them and get this machine working. It doesn't have many hours on it as I had it stored for about 5 years. Thanks again.
  #8 (permalink)
Old 05-18-2010, 01:12 AM
Senior Expert
APP Volunteer
Default
The Sears parts site is down right now so I can't get timer info. If the timer is thin and riveted together, it would be hard to get the cleaning spray near the contacts.
If it where my timer, I would drill out one rivet to enable opening it slightly to spray inside. You can allways seal it with rubber cement.
If that fails, you will need a new timer.
__________________
  #9 (permalink)
Old 05-18-2010, 11:08 PM
Junior Member
Default
Thanks, how can I get to the rivets. Does the knob come off? I've pulled it out as far as seems possible without breaking it. If you are able to supply me with a link to Sears parts for the timer, I would appreciate it.
  #10 (permalink)
Old 05-19-2010, 01:49 AM
Senior Expert
APP Volunteer
Default
If a plastic timer, the knob instructions are printed on the back. Generally, you use needle nose pliers to pull the back tab out, then remove timer knob.
Sears parts site is ********************************.com No competition to this site as prices are higher and web site slow.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore oven not heating to dial setting kings113 Oven Repair (including Ranges and Cooktops) 0 12-14-2008 06:17 PM
Washer fills and agitates but dial does not move forward hlmillerwb Washer Repair 1 10-29-2008 03:06 PM
Agitates and spins forever but dial won't move darnwasher Washer Repair 1 04-21-2008 03:32 AM
Kenmore washer 80 top agitator does not move with bottom agitator erbaker Washer Repair 1 02-19-2008 11:11 AM
Kenmore Washer Dial won't move rrmiles Washer Repair 0 01-22-2008 11:25 AM
