| » Kenmore washer dial doesn't move |
There are only a few sites using factory part numbers, Sears is one. Just crunch in the part # they give at Sears into this site and it will give you a new # with AP in front of it at a reduced cost.
__________________
I finally got to Sears Parts when it wasn't down. The part for the timer is 3951708. This site has 3 pics and it looks like the timer is encased in plastic. If you can would you have a look and see if there is anything you would recommend me trying with the contact cleaner and that timer. If I have to replace it, how difficult is it to get to. Do I need to pretty much dissemble the washer. Thanks again for your knowledge.
Edited. Just spent some time searching for how to open up the control panel. It's too late to look today, but if I read it right, I pop the side caps off and look for 2 screws (1 per side) that hold the control panel down. Remove screws and pull towards the front and up. Then I should have access to the timer. Does sound correct? Thanks again Last edited by RandallFlagg : 05-31-2010 at 12:46 AM. |
Timer part # here is AP3100179. I would pry open the cover opposite the connector with a putty knife and spray the contacs inside, then close it and seal with a piece of nylon packing tape.
__________________
Sorry it took so long to reply. I finally tried your latest advice today, but it didn't fix the problem. I removed the timer assembly and pried the top off. It broke a couple of little tabs, but the tape held it on reassembly. I made sure to spray the brass arms really good. There were a few rows of them and I tried to get to all of them. I reassembled the timer and ran it, but I still didn't get the knob to move. I'm sure it's the timer, I just hate to spend $75 for a new one and find it doesn't fix the problem either. That would blow! Before I go that route, I wanted to see if you have any more suggestions. Thanks as always.
| Display Modes | |
| kenmore oven not heating to dial setting | kings113 | Oven Repair (including Ranges and Cooktops) | 0 | 12-14-2008 06:17 PM |
| Washer fills and agitates but dial does not move forward | hlmillerwb | Washer Repair | 1 | 10-29-2008 03:06 PM |
| Agitates and spins forever but dial won't move | darnwasher | Washer Repair | 1 | 04-21-2008 03:32 AM |
| Kenmore washer 80 top agitator does not move with bottom agitator | erbaker | Washer Repair | 1 | 02-19-2008 11:11 AM |
| Kenmore Washer Dial won't move | rrmiles | Washer Repair | 0 | 01-22-2008 11:25 AM |
