| » Washer Rinse cycle problem |
Model Number: 417.90802990 Brand: Kenmore Age: 1 - 5 years
Water siphons out during rinse cycle, pump not running. Noticed washer motor got hot. The drain stand pipe is at 33", drain hose loop up at 48"
some times it works O K. I removed agitator and cleaned filter. This is a stacked unit with dryer on top. It worked fine since new in the same location. I also checked all the electrical connections , and they looked fine. |
Did it try to spin during the agitation?
__________________
Professional appliance repair in Los Angeles, California. |
did not try to spin in rinse cycle. I have a 40' drain hose outside on a good down hill slant. I disconected half of it and rinse cycle is working fine now.
this is an odd problem, could it be that the hose has enough friction or suchon. or is it just a temporary decided to work O K. I flushed drain hose with pressure fom garden hose???? |
| Display Modes | |
| Washer fills on wash cycle and rinse cycle and won't stop filling! | riphinney | Washer Repair | 15 | 03-12-2008 06:30 PM |
| Washer won't agitate or spin after rinse cycle | tickytutt | Washer Repair | 1 | 03-11-2008 11:31 AM |
| Washer won't spin in rinse cycle | PIETOWN | Washer Repair | 1 | 01-28-2008 02:13 PM |
| GE Washer will not spin on rinse cycle | mguy77 | Washer Repair | 1 | 01-15-2008 07:37 PM |
| washer keeps repeating the rinse cycle | hiltonacres | Washer Repair | 2 | 12-13-2007 08:22 PM |
