Discuss
GE washer wont spin belt appears loose
 in
Washer Repair
GE washer won't spin. I opened it up and found that the belt is loose and there is a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer wont spin belt appears loose
  #1 (permalink)
Old 06-17-2008, 10:43 PM
parkman009 parkman009 is offline
Junior Member
parkman009 is on a distinguished road
Question GE washer wont spin belt appears loose
Model Number: wpsr3100w1ww   Brand: GE   Age: 1 - 5 years
GE washer won't spin. I opened it up and found that the belt is loose and there is a pile of black belt rubber dust. Both pulleys turn freely. I easily removed the belt with my hand. It appears to me that the belt some how got loose and now needs to be replaced and the mechanism adjusted some how to tighten the belt. What happened and how do I fix it?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-18-2008, 08:39 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Any belt can get worn out due to age. There is not any kind of belt tension adjuster in your washer. A new belt should fit properly without it.
- The part number for the belt is AP2044592
Here are the break down diagrams for the GE washer Model WPSR3100W1WW
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-19-2008, 12:13 AM
Junior Member
Default loose belt on ge washer
Gene,
So, you think its just a worn belt and not a bad clutch? Is there anything special about how to install a new belt? The worn one was so loose it came off easily.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spin Belt Replacement on Amana Clothes Washer arlo whiting Washer Repair 0 01-12-2008 04:40 PM
washer wont spin BigMike Washer Repair 0 01-02-2008 08:37 AM
washer wont spin padgeneb Washer Repair 0 12-20-2007 10:54 AM
Older Kenmore washer appears "dead"! Cappy Washer Repair 0 10-27-2007 08:18 PM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
