Discuss
Front end washer door locked
 in
Washer Repair
I was having problems getting water to drain after the washer went through entire cycle. Now, the door is locked......
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Front end washer door locked
  #1 (permalink)
Old 06-17-2008, 04:07 PM
sindeye sindeye is offline
Junior Member
sindeye is on a distinguished road
Unhappy Front end washer door locked
Model Number: WBVH6240   Brand: GE   Age: 1 - 5 years
Now, the door is locked......no controls work, it just says door locked. I tried unplugging and leaving overnite but when plugged back in it is the same.
Help I have a load of clothes washed sitting in the washer - yuck.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-17-2008, 10:50 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
To manually unlock the door remove the bottom panel first. Reach behind and up the right side of the front panel, pull the release ring down, then open the door.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer front loader door wont stay latched d16ej1 Washer Repair 3 07-02-2008 04:58 PM
Oven Door Locked Planorez Oven Repair (including Ranges and Cooktops) 0 01-12-2008 08:15 AM
Duet Washer Door Locked Closed. Lucresha Washer Repair 1 01-07-2008 05:18 AM
Oven Door Latch Locked W/O Door hseeger Oven Repair (including Ranges and Cooktops) 2 12-28-2007 12:42 PM
Door latch broken/Door locked kitade Dishwasher Repair 2 10-23-2007 11:42 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
