| » removing covers from a Hotpoint Washing Machine |
Model Number: VBXR1070W0WW Brand: Hotpoint Age: 5 - 10 years
I've taken apart many a washer, but this one doesn't seem to fall for the same tricks as others. I have the exploded picture, but cannot find the secret sequence to actually take the top or front cover off.
It's probably like one of those wooden puzzles, where you slide the doohickey first, then squeeze the dinglebob, and push the hidden flugeldinger. I just can't figure it out for this particular model. Can anyone help? I'm doing this for an elderly neighbor who calls me to fix things for her. Thanks, Rus |
Get a putty knife, at the top of the front cover ( that gap between the front panel and lid assembly) are 2 spring clips that hold the front panel on. Find the spring clips, about 2-3 inches in from the side. push your putty knife in there on both sides, and the front panel comes right off
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
From the front twards the back
__________________
No problem
__________________
My moms washer was leaking for the longest time and just moved back in her house to help her out . Washer was leaking only on the Spin Cycle...Everything else worked fine. Popped the lid like Cheetohman said and wah-lah.... found the hole where a plug used to go...plugged it Butyl Rubber caulking and will see if this does the trick...Thanks for telling how to pop the lid Cheetoh...... Saved me alot of aggravation. Dano15022
| Display Modes | |
| washing machine | Mark Given | Washer Repair | 1 | 04-30-2008 08:04 PM |
| washing machine | Donald Belanger | Washer Repair | 4 | 12-11-2007 07:32 PM |
| Washing Machine | NIKKIMAN13 | Washer Repair | 0 | 11-17-2007 02:18 PM |
| washing machine takes hours to finish washing a load | kelly Monday | Washer Repair | 2 | 09-26-2007 03:42 AM |
| GE washing machine | paul | Washer Repair | 2 | 07-19-2007 08:13 PM |
