The rubber gasket on our Samsung washer was damaged and now it leaks! How can I install a new gasket?
The model number you posted does not come up. Verify and repost it.
I checked the serial number and from what I see, it is correct. Here is an attached photo. Thank you for your help. Bootmaker attached the following image(s):
