I just replaced the water inlet valve on my Whirlpool Duet front load washer. All went extremely smooth, but when reassembled the power is not coming on. I verified the breaker, used a hair dryer to ops check the outlet and verified door limit switch is being closed....any ideas? Thanks
Check to make sure you reconnected any wires. Also, make sure the water is turned back on.
