I have a General Electric WBSR3140G0WW Washer; plugs into an electric water shut off device called "Intellaflow by Watts". The washer cycle completes but the Intellaflow device light marked "Washer on" stays on. The Intella flow device hums - that indicates the washer is still on and still asking for power. I try to manually turn the washer dial to get to an "off" spot on the dial, cannot. Every position leaves the Intelloflow Washer On light on. Any suggestions on how to troubleshoot? many thanks
