Discuss
Washer door won't open
 in
Washer Repair
I put the washer in the pause mode. When I went to start the washer, it wouldn't start. Message '
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer door won't open
  #1 (permalink)
Old 06-15-2008, 07:18 PM
JFried1230 JFried1230 is offline
Junior Member
JFried1230 is on a distinguished road
Default Washer door won't open
Model Number: MAH550OBWW   Brand: Maytag   Age: 5 - 10 years
I put the washer in the pause mode. When I went to start the washer, it wouldn't start. Message 'do' and 'fl' kept appearing when I tried to start the washer. Tried shutting it off, and unplugging it. Did this several times. Left it alone for an hour or so, and tried again, still nothing. The door locked light was never on when the 'do' message appeared.
We have not tried to take the door off, but to no avail. How do you get the door to unlock when the door won't open? Or could clothes be stuck in there somehow?j
Any suggestions.
Thanks you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-16-2008, 04:18 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove the top left soap dispenser and pull on the nylon cord, this should open the door.
If the washer will not lock the door, you probably have a blown control board in back of the control panel. Also, replace the wax motor and put a 1000 joule surge protector on the wall outlet
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door Won't Open lmcintire Dishwasher Repair 1 06-12-2008 03:45 PM
Bosch Washer WFK2401 DOOR DOES NOT OPEN sakschul Washer Repair 0 04-21-2008 11:07 AM
dryer says door is open - it's not THOR Dryer Repair 1 04-10-2008 05:35 PM
Door won't open JT2469 Oven Repair (including Ranges and Cooktops) 3 03-05-2008 05:53 PM
Door Locked Open chrisc2007 Washer Repair 1 11-14-2007 08:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
