I have a Calypso Washer with Calypso Wash Motion, HE. The model number can not be found anywhere on the unit, even in the areas that you suggest. My question is ....on Cycle "Hand Wash" or "Delicate-Casual" will work up to the 25 minutes and then get stuck. If I switch it to "rinse and spin" it gets stuck at 7 minutes. If, I then switch it to extended spin, sometimes it will finish the load. The normal setting will show the codes, "CE", or "CA" or "CL". I have checked the water line hoses, and have cleaned the unit, all is good. I had an extended service plan (4 year), through the retail store where I purchased the unit. I could not afford to continure the plan. Please, I would appreciate any and all the help that you can provide me. Please list possible parts and prices.
Thank you,
futureheat
