Discuss
kenmore oasis
 in
Washer Repair
washer showed error code F-50. trouble shooting said to replace main control board, so I ordered a new board
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore oasis
  #1 (permalink)
Old 06-13-2008, 08:38 AM
rod767 rod767 is offline
Junior Member
rod767 is on a distinguished road
Default kenmore oasis
Model Number: 110.27052600   Brand: Kenmore   Age: Less than 1 year
washer showed error code F-50. trouble shooting said to replace main control board, so I ordered a new board with you.
My old board p/n is W10104820, the new board from you is p/n W10188476 Rev.A
when I plug in the new board, and turn on power, I get an error code F-2 now. That code means control board user interface error. What should I do?
Your site shows the two boards as the same, and visually they do look exactly the same. Is there some sort of reset to get the interface to recognize the new board?
Thank for any help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-15-2008, 05:03 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Rod,
Did you perform all tests as recommended in the tech sheets to diagnose the cause of the "F-50" fault code? If you did - post the results. If you did not - how did you know that the control board is bad?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-15-2008, 06:24 PM
Junior Member
Default
Thanks for ansewering Gene, yes I did, and the final outcome was to replace the control board.
  #4 (permalink)
Old 06-15-2008, 11:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by rod767 View Post
...My old board p/n is W10104820, the new board from you is p/n W10188476...
Did you get this part number (W10104820) form the old part or somewhere else?
__________________
  #5 (permalink)
Old 06-16-2008, 05:21 AM
Junior Member
Default
yes, I got the part num right off of the board.
  #6 (permalink)
Old 06-16-2008, 03:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Rod,
Looks like Whirlpool provided wrong part number cross over for this control board. According to Sears data base, per the model number you posted, the right part number for this control board is W10201186 which is Appliance Parts Pros item number AP4355605.
You have to contact Adam from Appliance Parts Pros customer service and he will help you to exchange this part.
__________________
  #7 (permalink)
Old 06-16-2008, 05:34 PM
Junior Member
Default
Thanks Gene, that's what I thought. I've started a return process, but they haven't emailed me back yet with the RMA. I'll try directly with Adam. Keep up the great work. You're priceless to this forum!!!
  #8 (permalink)
Old 10-06-2008, 04:22 PM
raf215 raf215 is offline
Junior Member
raf215 is on a distinguished road
Default Kenmore Elite Oasis HE Model # 110.27082603
I've got a slightly different problem with my Kenmore washer. The model is 110.27082603. Over the weekend it started behaving very different. Tried doing some laundry over weekend and needless to say it didn't run very well. I selected Towels/Sheets and once it started it kept toggling back and forth between 45 minutes/no spin to 58 minutes/2nd spin. I stopped the machine.
Early this morning, washer was beeping - got up and display was flashing F2 - user interface - is it the control board (same # as what's already been mentioned in thread) or user interface board? Have done some calling around and the consenses is control board.
Thanks in Advance,
Ray
  #9 (permalink)
Old 10-06-2008, 07:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Ray,
Control board and user interface board are both an electronic parts and your washer has both of them.
- The part number for the user interface board is AP3919482
__________________
  #10 (permalink)
Old 10-07-2008, 08:19 AM
Junior Member
Red face
Hi Gene,
Thanks for the quick reply. This morning I tried to run another Towel/Sheet wash. Initial display was 45 minutes/no 2nd spin. I did not press any buttons on the front and the display went to 60 minutes with a 2nd spin then a minute or 2 later it went back to 45 minutes/no spin. It sounds to me like it's the control board since I didn't touch any buttons.
I've got Sears scheduled to come out tomorrow but I am a DIYer so if you have the controller, I'd rather order the part and cancel the appt since I'd be paying the tech for something that I already know what's wrong.
BTW, would you have a tech sheets for this model washer?
Thanks in Advance,
Ray
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Oasis F1 Code Vacy72 Washer Repair 4 07-01-2008 09:56 AM
Kenmore Elite Oasis: no light jkok2000 Washer Repair 0 03-05-2008 04:04 PM
Kenmore Oasis 28032/Whirlpool WTW6200S warm water temp GeorgeG Washer Repair 0 01-22-2008 12:52 PM
Oasis he lrryoung Washer Repair 0 11-12-2007 05:58 PM
Oasis HE - how to open for cleaning? ksevern Washer Repair 1 08-04-2007 10:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
