| » Drain pump replaced, now timer stops after wash and will not rinse |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: FWT449GFS1 Brand: Frigidaire Age: 5 - 10 years
I replaced the drain pump on my washer with a redesigned pump (original design no longer available according to various sources) due to debris ($3.75 in change)getting sucked in it and breaking off the impeller vanes, but now the timer runs to the end of the wash cycle, drains the tub and just stops and buzzes, won't advance into rinse cycle. Did I miss something in the pump replacement or di I now have a bad timer?? Any help is Greatly appreciated!
Sounds as if the water coming to the machine may not be working. start your machine and change water temps to make sure both hot and cold water flow through the machine
__________________
Who wants a chance to win $10,000 a week for the next 17 weeks? How about $250,000 if you have the most points after 17 weeks. The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
| Display Modes | |
| Washer stops at Rinse Cycle and doesn't drain water | kukoch | Washer Repair | 5 | 06-04-2008 12:44 AM |
| Timer stops after wash cycle | YODAUSA | Washer Repair | 5 | 05-13-2008 12:12 PM |
| Replaced Chopper - Is Pump OK? | crtwood | Dishwasher Repair | 1 | 03-22-2008 03:34 PM |
| Dishwasher skips the wash cycle and stops at the rinse cycle | jasporo | Dishwasher Repair | 1 | 11-16-2007 05:12 PM |
| Starts to pump during wash then shuts down, starts, stops real quidk | sirgalagit | Dishwasher Repair | 1 | 10-03-2007 08:23 PM |
