Discuss
Washing machine stops and beeps at me
 in
Washer Repair
I have a Kenmore front loader. When I start the washing machine and it is filling with water, it stops
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washing machine stops and beeps at me
  #1 (permalink)
Old 04-09-2010, 10:16 PM
Junior Member
Tooley is on a distinguished road
Default Washing machine stops and beeps at me
Model Number: 41744152400   Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore front loader. When I start the washing machine and it is filling with water, it stops after a few minutes and it beeps at me with the lights flashing. If I press the button again, it will continue to fill up with water. After a while the machine, beeps at me with the lights flashing. I see that there is still water in the washing machine. So I gues it stops when it is supposed to drain. But yet I can move the handle to the drain and spin cycle and it will do that. Also during this whole process the door stays in the locked position even if I press cancel on the washing machine. Does anyone know why it is doing that?
I read somewhere that if your machine stops in the spinning cycle that is the door lock assembly. But my washing machine has also stopped near the beginning of the cycle.
Thanks for your help.
Related Models
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
Kenmore 41783142300 DRYER
Kenmore 41784042500 DRYER
Kenmore 41784052500 DRYER
Kenmore 41784072300 DRYER
Kenmore 41784082500 DRYER
Kenmore 41784092500 DRYER
Kenmore 41784130000 DRYER
Kenmore 41784131000 DRYER
Kenmore 41784132000 DRYER
Kenmore 41784152500 DRYER
Kenmore 41784252500 DRYER
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41787042700 DRYER
Kenmore 41788042700 DRYER
Kenmore 41788052700 DRYER
Kenmore 41788056700 DRYER
Kenmore 41788076700 DRYER
Kenmore 41788988100 ELECTRIC DRYER
Kenmore 41788988800 ELECTRIC DRYER
Kenmore 41788989100 GAS DRYER
Kenmore 41788989800 GAS DRYER
Kenmore 41789090100 WASHER DRYER COMBINATION
Kenmore 41789090110 COMBINATION WASHER-DRYER
Kenmore 41789090200 WASHER DRYER COMBINATION
Kenmore 41789090210 COMBINATION WASHER-DRYER
Kenmore 41789090400 WASHER DRYER COMBINATION
Kenmore 41789090410 COMBINATION WASHER-DRYER
Kenmore 41789090600 WASHER DRYER COMBINATION
Kenmore 41789090610 COMBINATION WASHER-DRYER
Kenmore 41789090800 WASHER DRYER COMBINATION
Kenmore 41789090810 COMBINATION WASHER-DRYER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
Kenmore 41789195810 COMBINATION WASHER/DRYER
Kenmore 41789195820 COMBINATION WASHER/DRYER
Kenmore 41789390100 COMBINATION WASHER/DRYER
Kenmore 41789390101 COMB, WASHER/DRYER
Kenmore 41789390110 COMBINATION WASHER/DRYER
Kenmore 41789390600 COMBINATION WASHER/DRYER
Kenmore 41789390700 COMBINATION WASHER/DRYER
Kenmore 41789390701 COMB, WASHER/DRYER
Kenmore 41789390710 COMBINATION WASHER/DRYER
  #2 (permalink)
Old 04-11-2010, 08:15 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
The flashing lights on this model are the way the machine gives you an error code, since it does not have an LCD display.
Take off the lower front panel, and inside on the left you should find a tech sheet that will tell you how to troubleshoot and interpret the codes.
I suspect the door lock assembly, which regularly fails on these Frigidaire made models, but see if you cannot get better confirmation from the tech sheet.
__________________
  #3 (permalink)
Old 04-11-2010, 11:37 AM
Junior Member
Default Lower front panel
How do I take off the lower front panel?
  #4 (permalink)
Old 04-11-2010, 11:48 AM
Senior Expert
APP Volunteer
Default
Use a quarter inch nut driver to take out the two screws at each edge at the bottom of the panel.
__________________
  #5 (permalink)
Old 04-11-2010, 01:56 PM
Junior Member
Default Beeping Lights
We pulled out the tech sheet and followed the instructions.
The sheet tells us to count the number of beeps and these instructions are very confusing. The instructions say to count the beeps and there is a pause and count the beeps for the second number. However my husband and I could not see any kind of pauses between beeps. We counted way beyond 15 and there is no error code for that. Now what do we do?
Thanks.
  #6 (permalink)
Old 04-11-2010, 03:30 PM
Senior Expert
APP Volunteer
Default
If the main control will not generate error codes it is likely the problem, but you will have to replace it to be certain.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing Machine stops in the middle of wash jchestnutt Washer Repair 0 02-18-2010 09:34 AM
Washing Machine Stops When Washing farmallnancy Washer Repair 1 12-01-2009 05:12 PM
washing machine stops after agitating cycle, doesn't drain or proceed to next cycle jjd2009 Washer Repair 2 11-13-2009 06:31 AM
Frigidaire washer stops during spin cycle and beeps 3 times FDAR Washer Repair 0 06-10-2008 07:33 PM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 02:42 AM
