Discuss
Kenmore Washer Wont Spin
 in
Washer Repair
I have a kenmore washer ( not sure how old) but it no longer spins. I was told I needed a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer Wont Spin
  #1 (permalink)
Old 06-13-2008, 06:11 AM
DOR122468@YAHOO.COM DOR122468@YAHOO.COM is offline
Junior Member
DOR122468@YAHOO.COM is on a distinguished road
Default Kenmore Washer Wont Spin
Model Number: 110.92380200   Brand: Kenmore   Age: 5 - 10 years
I have a kenmore washer ( not sure how old) but it no longer spins. I was told I needed a coupling, which I bought. However, I cannot figure out how to install it. I tipped the machine on its side to access the bottom. The coupling is wedged between, what I think is the motor and a metal covering, which may be the transmission. I am not sure how to remove the motor ( there doesnt seem to be any bolts). Do I have to remove the metal piece? I am a single mom and cannot afford to pay a repairman, so I am determined to do this myself. Any help would be greatly appreciated. Thank you!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-13-2008, 06:58 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Before we proceed with the coupling replacement I need you to answer on these questions:
Did it agitate?
Did it drain?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-14-2008, 12:08 PM
Junior Member
Default
Hi Yes it did agitate and drain.
  #4 (permalink)
Old 06-15-2008, 05:03 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You probably have a bad clutch. Will need to pull tranny to change.
__________________
  #5 (permalink)
Old 10-02-2008, 08:33 PM
Tgarvey Tgarvey is offline
Junior Member
Tgarvey is on a distinguished road
Default Kenmore Washing machine will not spin
My first problem began when my motor coupler broke and I received a replacement (newly designed with metal inserts on each side of the plastic pieces of the coupler). I replaced the couple and did a test run with no clothes and all the cycles completed successfully. I then put just a few clothes into the drum and tried this again......no go. The machine will agitate fine but when it begins the spin cycle, I can hear the relay clicking trying to engage the motor to spin the tub over and over again quickly then just stops. The tub does begin to spin for about 3 seconds then just stops.
I read through some of your other forums and I unfortunately did pick the transmission up the shaft a couple times. I can spin the coupler and see the motor and transmission shaft turn. Should I focus on the tub now?
Any suggestions?
Todd-
  #6 (permalink)
Old 10-02-2008, 08:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Todd,
What is the complete model number of the washer?
__________________
  #7 (permalink)
Old 10-02-2008, 09:35 PM
Junior Member
Default
Hey Gene, I don't have the exact data that you are asking for. All I know is that its a Kenmore 90 series Super Capacity Plus with the Quiet Pack III and it was bought new in 1998 from Sears. I just pulled the control pannel and see that the manufacturer left the wire diagram but it doesn't come out and say any particular model number...all I see on wire diagram is part no: 3953250
Not sure if this helps.
Todd-
  #8 (permalink)
Old 10-03-2008, 01:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Todd,
Usually the name plate with model number is under the lid.
__________________
  #9 (permalink)
Old 10-03-2008, 08:35 PM
Junior Member
Default Model number
Gene,
Here is the model number: 110.20902990
Type: III
  #10 (permalink)
Old 10-03-2008, 10:24 PM
Junior Member
Default
Gene,
I was eager to tear into the washer again to find out what could be causing the problem so I basically stripped the washer down to just the tub and the support frame. I was careful to note where everything goes so going back together will not be an issue. However, I took a closer look and the transmission and the splined shaft and noticed that when I stick the shaft directly upward there is play left and right and I fairly certain there shouldn't be any. Would you agree? Also, with all the components removed, it still feels like the tub is not easy to spin. I guess I'll need to go test out how easy it is to spin a new unit from the store. Any suggestions would be helpful. Please respond.
Todd-
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer wont spin labfreak Washer Repair 2 04-10-2008 07:51 AM
washer wont spin BigMike Washer Repair 0 01-02-2008 08:37 AM
washer wont spin padgeneb Washer Repair 5 12-27-2007 08:57 PM
washer wont spin aliciakr Washer Repair 0 11-05-2007 08:56 AM
kenmore spray arm wont spin bh77521 Dishwasher Repair 2 09-14-2007 04:03 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
