Hi, My GE coin operated washer does not drain after wash and rinse cycles. I have part # of the pump assembly.
My problem is: I cant open the front panel of the washer. I know that the top panel has a fake lock.
I searched the web about this but cant find any helpful information. One guy wrote somewhere that he inserted a flat screw driver beteen the front and side panel and he could open the front cover. I tried the same with out luck.
I can see a nylon stud like thing on the either side of the front panel. And there is pin like metal wire between the front and side panel on the right side of the front panel.
I will greatly appreciate if someone experience can give me step by step instructions on how to do this.
Thanks in advance. Adam.
