Discuss
GE Washer won't drain
 in
Washer Repair
When this problem started, The tub would drain normally after wash cycle. Then after rinse cycle, machine would only make
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer won't drain
  #1 (permalink)
Old 06-12-2008, 08:57 AM
Wannafix Wannafix is offline
Junior Member
Wannafix is on a distinguished road
Default GE Washer won't drain
Model Number: WLE4000B1WW   Brand: GE   Age: 5 - 10 years
When this problem started, The tub would drain normally after wash cycle. Then after rinse cycle, machine would only make a motor noise and wouldn't drain. After moving dial around to wash again, it didn't drain after wash cycle. I removed front cover, and removed pump. Inspected hole in bottom of tub, and the output tube from the pump, both to be unobstructed. Connected the wires back to the pump(while pump was removed) and ran the machine. I can see the impeller blades turning normally. Water will drain if I hold the waste pipe from washer, horizontally into a bucket, but not when its vertical into the house drain. I reinstalled the pump, and still have same problem. I unplugged washer and left it over night, next morning I plugged it back in, and it drained normally only after wash cycle again. Does the pump's impeller blades supposed to move like a car starter(in and out) in order to pump the water, or does it pump water just by spinning the impellers?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't drain MMBell Washer Repair 4 07-28-2008 01:51 PM
Washer won't drain nsimone1056 Washer Repair 7 05-22-2008 06:18 PM
Washer won't drain lk2ski Washer Repair 0 04-14-2008 09:33 AM
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 02:41 PM
Washer won't drain jmcdonald62 Washer Repair 0 11-20-2007 08:19 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
