Discuss
Slow fill in rinse, Kenmore Elite
 in
Washer Repair
About 15 seconds into the fill of the Rinse cycle,with warm water selected, the Hot Water cuts out which
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Slow fill in rinse, Kenmore Elite
  #1 (permalink)
Old 06-11-2008, 02:08 PM
cclzcec32401 cclzcec32401 is offline
Junior Member
cclzcec32401 is on a distinguished road
Default Slow fill in rinse, Kenmore Elite
Model Number: 110.24952300   Brand: Kenmore   Age: 1 - 5 years
About 15 seconds into the fill of the Rinse cycle,with warm water selected, the Hot Water cuts out which takes the machine FOREVER to fill with cold water only coming in!!!
This only happens in the Rinse cycle, the Wash cycle (also using warm water,) works fine!!!
Chris
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-11-2008, 02:19 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
The rinse cycle use cold water, so use the cold fill on regular wash and see if it is slow then, if it is, check your hose screen for a clog
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 06-11-2008, 02:24 PM
Junior Member
Default
I am using warm water for the rinse, which mixes hot and cold water.
The hot water cuts out, leaving only cold water.
No hoses can be clogged because the wash cycle (also using warm water,) works fine!
  #4 (permalink)
Old 06-11-2008, 02:27 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Check the screens for blockage, sand grit can build up on the screens and cause a slow fill, hot water valve can clog from water heater sediment, and cold water can clog from the city water supply.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
final rinse runs slow and smell mnethery Washer Repair 1 06-07-2008 12:25 AM
Slow cold water fill skirven2 Washer Repair 1 04-25-2008 11:17 PM
washer wont fill or rinse or final spin Kangasr25 Washer Repair 0 04-23-2008 08:25 PM
maytag washer wiil fill slow on spin cycle sancortez Washer Repair 0 04-11-2008 07:34 PM
Washer is slow to fill Dbowls Washer Repair 1 08-30-2007 03:22 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
