Discuss
washer, top load
 in
Washer Repair
My washer is starting to leak water down below the tub only in the spin cycle. It is 26 years
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer, top load
  #1 (permalink)
Old 06-11-2008, 01:10 PM
Ger Ger is offline
Junior Member
Ger is on a distinguished road
Default washer, top load
Model Number: HA2621   Brand: Speed Queen   Age: More than 10 years
My washer is starting to leak water down below the tub only in the spin cycle. It is 26 years old machine. I was thinking of replacing all of the seals. Is it worth the time and effort to fix this machine that has worked do well for 26 years???????????? What is the trick to getting the agitator cap off???????????
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-11-2008, 01:11 PM
Ger Ger is offline
Junior Member
Default
Yes, the washer will fill and it will run
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Load Washer dball2470 Washer Repair 0 02-20-2008 08:33 AM
frigidaire front load washer JMS Washer Repair 1 02-03-2008 11:43 AM
whirlpool washer won't drain with load kimchu Washer Repair 8 01-16-2008 04:24 PM
front load ge washer renwick Washer Repair 0 01-09-2008 10:43 AM
Top Load washer problem mrcmorrison Washer Repair 2 08-29-2007 09:09 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
