Discuss
Maytag spins rinses and drains but clothes wet
 in
Washer Repair
Our Whirlpool 7 cycle/2 speed washer has started leaving clothes wet although it runs through the spin/rinse/drain
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag spins rinses and drains but clothes wet
  #1 (permalink)
Old 06-10-2008, 09:00 PM
PoppaDick PoppaDick is offline
Junior Member
PoppaDick is on a distinguished road
Default Maytag spins rinses and drains but clothes wet
Brand: Whirlpool   Age: 1 - 5 years
Our Whirlpool 7 cycle/2 speed washer has started leaving clothes wet although it runs through the spin/rinse/drain cycle seemingly fine...except the rinse water keeps rinsing until the spin has stopped, then shuts off.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-11-2008, 06:55 AM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Look into the pump
Check to see if anything is in the pump. If the water sprays continuously till the end of the cycle then naturally the clothes will be wet. It may be that the timer is messed up Does it do it in all cycles?
  #3 (permalink)
Old 06-11-2008, 08:03 PM
Junior Member
Talking Timer vs. Pump
Yes, it is the same in all cycles. Timer was my first guess. I'll have to figure out where the pump is, huh? Thanks.
  #4 (permalink)
Old 06-11-2008, 10:03 PM
Senior Expert
APP Volunteer
Default the pump mounts on the motor
remove the cabinet by flipping up the control panel and umplugging this lid switch connection right here:a lid-switch-unplug.jpgPOP them purty brass S clips with a long flat blade and remove the cabinet. The pump and other innards of interest will be revealed.
  #5 (permalink)
Old 06-11-2008, 10:07 PM
Senior Expert
APP Volunteer
Default More interesting case removal pixs
lokky here at this breakdown of a whirlpool direct drive washing machine like yours:direct drive cabinet removal.jpg
  #6 (permalink)
Old 06-11-2008, 10:09 PM
Senior Expert
APP Volunteer
Default the pump mounts on the motor for easy repair
It just clips onto the motor(number 22 is the pump):a DD breakdown.jpg
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag spin cycle does not get enough water out of clothes mitchel chad Washer Repair 2 03-26-2008 04:08 PM
whirlpool washer spins ok,but clothes are still heavy hotrodron Washer Repair 1 03-13-2008 05:16 AM
Maytag Washer spins instead of agitating blur Washer Repair 2 03-04-2008 03:36 PM
Maytag drains before wash cycle markm196 Dishwasher Repair 0 02-09-2008 10:11 AM
Maytag Neptune Clothes washer AnnieB Washer Repair 1 09-19-2007 05:03 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
