Discuss
Washer drum not balanced
 in
Washer Repair
Bought a washer 3rd hand from a friend of a friend. I'm unsure exactly how old it is. We
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer drum not balanced
  #1 (permalink)
Old 06-10-2008, 08:32 PM
Cat12 Cat12 is offline
Junior Member
Cat12 is on a distinguished road
Default Washer drum not balanced
Model Number: 82873800   Brand: Kenmore   Age: 5 - 10 years
We had some trouble getting it moved and probably jarred something loose. My dad consulted a parts place and we noticed that the water spout at the top where the water enters the drum seemed loose. Diagnosis was a potential leaky seal in the outer plastic tub and the loose spout. We ended up tearing it down to the base to replace the tub seal.
The water spout is new and the seal has been replaced. However, there is still a leak. The drum has a lot of "give" to it and seems out of place. You have to shove it forward to get all the water in the drum. Every time it rinses I have to shove the drum forward to make sure all the water goes in.
Any suggestions? My (completely amateur) thought is when replacing the stabilizer plate, we didn't get it in right. Hence the drum is not being held up enough in the front to get all the water in. Dad is thinking of propping it up more but its up on as much as it will go and about 2 inches more on stacks of paper. Any suggestions on what we could do to get the drum stable again? It spins, its just slumped forward.
P.s. your diagram links in another forum reply were very helpful in the first repair. We couldn't really get the stablizer plate in well and couldn't really see where it went which might be part of the problem.
Suggestions from the experts? We would really hate to tear it down again I admit.
Related Models
Amana 8291.A Mwave - Family Size (60 Hz)
Amana 8294.A Mwave - Family Size (60 Hz)
Amana 8294.B Mwave - Family Size (60 Hz)
Magic Chef 82FA-1 Surface Unit - Gas
Magic Chef 82FA-12 Surface Unit - Gas
Magic Chef 82FA-12K Surface Unit - Gas
Magic Chef 82FA-1K Surface Unit - Gas
Magic Chef 82FG-1K Surface Unit - Gas
Magic Chef 82FK-1
Magic Chef 82FK-1K Surface Unit - Gas
Magic Chef 82FN-1 Surface Unit - Gas
Magic Chef 82FN-1K Surface Unit - Gas
Magic Chef 82FS-1 Surface Unit - Gas
Magic Chef 82FS-12 Surface Unit - Gas
Magic Chef 82FS-12K Surface Unit - Gas
Magic Chef 82FS-1K Surface Unit - Gas
Magic Chef 82FY-1 Surface Unit - Gas
Magic Chef 82FY-1K
Magic Chef 82HA-1 Surface Unit - Gas
Magic Chef 82HA-12 Surface Unit - Gas
Magic Chef 82HA-1K Surface Unit - Gas
Magic Chef 82HA-2K Surface Unit - Gas
Magic Chef 82HN-1 Surface Unit - Gas
Magic Chef 82HN-1K Surface Unit - Gas
Magic Chef 82HN-2K Surface Unit - Gas
Magic Chef 82HS-1
Magic Chef 82HS-1K
Magic Chef 82HS-2K Surface Unit - Gas
Magic Chef 82HW-1K
Magic Chef 82HY-1K
Magic Chef 82JA-2K Surface Unit - Gas
Magic Chef 82JK-2K
Magic Chef 82JN-2K Surface Unit - Gas
Magic Chef 82JS-2K
Magic Chef 82LA-1 Surface Unit - Gas
Magic Chef 82LA-2K Surface Unit - Gas
Magic Chef 82LK-2K Surface Unit - Gas
Magic Chef 82LK-3K Surface Unit - Gas
Magic Chef 82LN-1 Surface Unit - Gas
Magic Chef 82LN-2K Surface Unit - Gas
Magic Chef 82LN-3K Surface Unit - Gas
Magic Chef 82LS-1 Surface Unit - Gas
Magic Chef 82LS-2K Surface Unit - Gas
Magic Chef 82LW-2K Surface Unit - Gas
Magic Chef 8311PA Surface Unit - Gas
Magic Chef 8311PS Surface Unit - Gas
Magic Chef 8311PW Surface Unit - Gas
Magic Chef 8311TA Surface Unit - Gas
Magic Chef 8311TS Surface Unit - Gas
Magic Chef 8311TW Surface Unit - Gas
Magic Chef 8320PA Surface Unit - Gas
Magic Chef 8320PB
Magic Chef 8320PS Surface Unit - Gas
Magic Chef 8320PW Surface Unit - Gas
Magic Chef 8320TA Surface Unit - Gas
Magic Chef 8320TS Surface Unit - Gas
Magic Chef 8320TW Surface Unit - Gas
Magic Chef 8321PA Surface Unit - Gas
Magic Chef 8321PB Surface Unit - Gas
Magic Chef 8321PS Surface Unit - Gas
Magic Chef 8321PW Surface Unit - Gas
Magic Chef 8321TA Surface Unit - Gas
Magic Chef 8321TB Surface Unit - Gas
Magic Chef 8321TS Surface Unit - Gas
Magic Chef 8321TW Surface Unit - Gas
Whirlpool 8340NFSBS00
Magic Chef 8341VB Surface Unit - Gas
Magic Chef 8341VD Surface Unit - Gas
Magic Chef 8341VS Surface Unit - Gas
Magic Chef 8341VV Surface Unit - Gas
Magic Chef 8351VB Surface Unit - Gas
Magic Chef 8351VD Surface Unit - Gas
Magic Chef 8351VQ Surface Unit - Gas
Magic Chef 8351VS Surface Unit - Gas
Magic Chef 8351VV Surface Unit - Gas
Magic Chef 8361RB Surface Unit - Gas
Magic Chef 8361RV Surface Unit - Gas
Magic Chef 8361RW Surface Unit - Gas
Magic Chef 83EA-1 Surface Unit - Gas
Magic Chef 83EA-1G Surface Unit - Gas
Magic Chef 83EA-1GK Surface Unit - Gas
Magic Chef 83EA-1K Surface Unit - Gas
Magic Chef 83EB-1G Surface Unit - Gas
Magic Chef 83EB-1GK Surface Unit - Gas
Magic Chef 83EN-1 Surface Unit - Gas
Magic Chef 83EN-1G Surface Unit - Gas
Magic Chef 83EN-1GK Surface Unit - Gas
Magic Chef 83EN-1K Surface Unit - Gas
Magic Chef 83EP-1GK Surface Unit - Gas
Magic Chef 83ES-1 Surface Unit - Gas
Magic Chef 83ES-1G Surface Unit - Gas
Magic Chef 83ES-1GK Surface Unit - Gas
Magic Chef 83ES-1K Surface Unit - Gas
Magic Chef 83ET-1GK
Magic Chef 83EY-1 Surface Unit - Gas
Magic Chef 83EY-1GK
Magic Chef 83FA-1 Surface Unit - Gas
Magic Chef 83FA-1G Surface Unit - Gas
Magic Chef 83FA-1GK Surface Unit - Gas
Magic Chef 83FA-1K Surface Unit - Gas
Magic Chef 83FG-1K Surface Unit - Gas
Magic Chef 83FK-1 Surface Unit - Gas
Magic Chef 83FN-1 Surface Unit - Gas
Magic Chef 83FN-1G Surface Unit - Gas
Magic Chef 83FN-1GK Surface Unit - Gas
Magic Chef 83FN-1K Surface Unit - Gas
Magic Chef 83FS-1 Surface Unit - Gas
Magic Chef 83FS-1G Surface Unit - Gas
Magic Chef 83FS-1GK Surface Unit - Gas
Magic Chef 83FS-1K Surface Unit - Gas
Magic Chef 83FY-1GK Surface Unit - Gas
Magic Chef 83HA-1 Surface Unit - Gas
Magic Chef 83HA-1G Surface Unit - Gas
Magic Chef 83HA-1GK Surface Unit - Gas
Magic Chef 83HA-1K Surface Unit - Gas
Magic Chef 83HN-1G
Magic Chef 83HN-1GK
Magic Chef 83HN-1K
Magic Chef 83HS-1G
Magic Chef 83HS-1GK
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore front load washer drum off balance and bangs in one location kemily Washer Repair 3 10-23-2009 06:56 AM
Drum wont fill on Maytag Washer ddrowe Washer Repair 0 04-29-2008 01:34 PM
Washer Drum out of balance dcophil Washer Repair 1 01-06-2008 11:09 PM
dryer drum wally gator Dryer Repair 0 11-22-2007 10:13 AM
Chriping noise when washer drum changes direction Rikam Washer Repair 0 11-19-2007 01:59 PM
