Discuss
Washer drum not balanced
 in
Washer Repair
Bought a washer 3rd hand from a friend of a friend. I'm unsure exactly how old it is. We
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer drum not balanced
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-10-2008, 07:32 PM
Cat12 Cat12 is offline
Junior Member
Cat12 is on a distinguished road
Default Washer drum not balanced
Model Number: 82873800   Brand: Kenmore   Age: 5 - 10 years
We had some trouble getting it moved and probably jarred something loose. My dad consulted a parts place and we noticed that the water spout at the top where the water enters the drum seemed loose. Diagnosis was a potential leaky seal in the outer plastic tub and the loose spout. We ended up tearing it down to the base to replace the tub seal.
The water spout is new and the seal has been replaced. However, there is still a leak. The drum has a lot of "give" to it and seems out of place. You have to shove it forward to get all the water in the drum. Every time it rinses I have to shove the drum forward to make sure all the water goes in.
Any suggestions? My (completely amateur) thought is when replacing the stabilizer plate, we didn't get it in right. Hence the drum is not being held up enough in the front to get all the water in. Dad is thinking of propping it up more but its up on as much as it will go and about 2 inches more on stacks of paper. Any suggestions on what we could do to get the drum stable again? It spins, its just slumped forward.
P.s. your diagram links in another forum reply were very helpful in the first repair. We couldn't really get the stablizer plate in well and couldn't really see where it went which might be part of the problem.
Suggestions from the experts? We would really hate to tear it down again I admit.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drum wont fill on Maytag Washer ddrowe Washer Repair 0 04-29-2008 12:34 PM
Washer Drum out of balance dcophil Washer Repair 1 01-06-2008 10:09 PM
kenmore front load washer drum off balance and bangs in one location kemily Washer Repair 2 12-18-2007 03:02 PM
dryer drum wally gator Dryer Repair 0 11-22-2007 09:13 AM
Chriping noise when washer drum changes direction Rikam Washer Repair 0 11-19-2007 12:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
