Discuss
Kenmore top load won't spin
 in
Washer Repair
I have a Kenmore 80 series Model # 110.23832100 washing machine. The problem is that it will not spin after
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore top load won't spin
  #1 (permalink)
Old 04-05-2010, 03:17 PM
Junior Member
dprokosc is on a distinguished road
Default Kenmore top load won't spin
Model Number: 110.23832100   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore 80 series Model # 110.23832100 washing machine. The problem is that it will not spin after the washing agitation, rinse agitation and spin cycles. It sound like it is starting these modes and the water will drain out but it will not spin. To correct it all I have to do is lift the lid and close it and then it will spin. I have put a pen in the switch to watch the cycles and when it is suppose to spin and doesn't all I have to do is remove the pen and put it back in the lid switch and it will spin it. I was told that maybe it was the clutch so I replaced that and it did not cure the problem.
Dale
Ads By Google
Related Models
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
  #2 (permalink)
Old 04-07-2010, 02:15 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Your problem is likely in the timer. The timer must pause the machine to cause the transmission to shift from neutral drain to spin. When you open the top you manually create this pause.
Change out the timer and you should be all set.
__________________
  #3 (permalink)
Old 04-07-2010, 06:24 PM
Junior Member
Default
when I watch and listen to the machine it is making a long pause before it goes into when it should spin it. Thats why I,m thinking it's not the timer. The timers are a little expensive so I really need to know if that's the problem. Any other suggestions or am I just gonna have to bite the bullet and buy a new timer?
  #4 (permalink)
Old 04-08-2010, 04:44 PM
Senior Expert
APP Volunteer
Default
Hi Dale
We cannot diagnose any problem with complete certainty on a Forum like this because we are not there to see the machine in operation. We can only tell you what is most likely the problem.
If the machine continues to operate the pump and will not go into spin unless you manually stop it by pushing in the timer or lifting the top so that the lid switch stops the machine, it is highly likely the timer is the problem. As I indicated, the timer must pause the machine to cause the transmission to shift from neutral to spin.
If you order the timer from this site and it does not fix the problem you may return it for a refund (but you will have to absorb the shipping costs). See the returns policy on this site for details.
__________________
  #5 (permalink)
Old 04-09-2010, 06:30 AM
Junior Member
Default
Thanks for the advise I think I will order a timer and try that. I will let you know what the results were. Thanks again Dale
  #6 (permalink)
Old 09-06-2011, 04:37 PM
Junior Member
tedmlane is on a distinguished road
Default Kenmore Series 80 won't Spin. Type 111 Mod 23832100
I'm having the same symptoms as the previous post. Do you know if the timer fixed the problem? How much is a new timer?
Symptoms are if you lift the lid and defeat the lid switch you can get the agitator spinning by hand and it will spin out the remaining water. I didn't play around with the sequence of operation to see if it was a timing issue.
Thanks, Ted
  #7 (permalink)
Old 09-06-2011, 07:09 PM
Senior Expert
APP Volunteer
Default
Please start a new thread and put in your model number and a detailed description of your problem. I don't understand exactly what you are saying, for example, will it spin with the lid open, will it spin without help or do you start it spinning by hand, then lower the lid to keep it going.
__________________
  #8 (permalink)
Old 09-07-2011, 03:17 PM
Junior Member
Default
Ok, I thought you had read the string that I added to so I wouldn't have to go into detail but sure, I'll start a new one.
  #9 (permalink)
Old 09-09-2011, 06:35 PM
Junior Member
Default
I bought a timer and put it in and it did not solve the problem. Seemed like it was going to cost me more than the machine was worth so I went and bought a new one. Sorry I couldn't help.
Good Luck
  #10 (permalink)
Old 09-10-2011, 04:39 PM
Junior Member
bsaucer is on a distinguished road
Default
Most Whirlpool/Kenmore direct-drive models feature a "neutral-drain" cycle. After the agitate cycle, it pauses a few seconds, and then goes into a "neutral drain" for two minutes or so. Then it will pause the motor a few seconds and restart, causing it to spin. This prevents it from spinning until it's empty.
Opening the lid during the "neutral drain" cycle and closing it again will cause it to "kick" into spin.
The "neutral-drain" state will "reset" during the agitate cycle, so that it can drain out again afterwards.
The behavior you describe is normal. However, if it doesn't pause once after two minutes of draining, then I'd worry (timer). Also, if it "kicks" into spin WHILE it is still draining (before the pause), I'd also worry (transmission).
Most other brands will normally spin while draining. Maytag calls this the "Swirl-Away" feature.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore top load won't agitate, spin, hums jeffraab Washer Repair 5 11-06-2009 05:29 PM
Front load Kenmore won't spin AlanS Washer Repair 1 10-12-2009 06:22 AM
Kenmore Front Load Another No Spin smurri Washer Repair 2 04-29-2009 10:54 AM
Kenmore front load won't spin marksholander@hotmail.com Washer Repair 2 01-06-2009 02:10 AM
Kenmore top-load washer does not spin or agitate HarryD Washer Repair 6 09-19-2008 02:57 PM
