| » Spin cycle is very loud, like a jet engine |
Model Number: Elite HE 110 Brand: Sears Age: 1 - 5 years
Everything works great with the washer but in the last month while on any spin cycle the noise makes it sound like I am in a airplane. It is very loud.
Any thoughts or suggestions? Ads By Google Related Models |
Check your warranty, I believe your tub bearings are guaranteed for 10 years.I would get it fixed soon before your motor/motor control blows out from the bearings increased friction.
__________________
You are correct, the tub/bearings are covered for 10 years. Parts will not be available for 10 days, the repairman said it shoulds be Ok to use, just loud. The question would be is the motor (control) part of this repair or would you recommend not to use it until repaired?
Your motor/ motor electronics are not covered under your warranty, just check and verify.
If you have an amprobe, check your washer current during high speed spin. If higher than 3 amps, you might have a problem. Also, if your motor shuts down during this period, it's probably shutting down on it's thermal overload. Syptoms would be motor shutdown and off for several minutes. You can also put this as a question in this forum, or call Whirlpool. Personally, I would not use it, you might do mechanical damage not covered under the warranty.
__________________
- Last edited by richappy : 04-10-2010 at 01:00 AM. |
| Display Modes | |
| loud spin cycle | yanusdj | Washer Repair | 0 | 03-16-2010 02:18 PM |
| Loud noise on spin cycle | ezeeric11 | Washer Repair | 0 | 03-06-2010 04:17 AM |
| Loud spin cycle | myrl1@charter.net | Washer Repair | 2 | 10-27-2008 02:34 PM |
| loud noise when in spin cycle | rzbackfan | Washer Repair | 2 | 05-23-2008 03:24 AM |
| Loud in spin cycle | djr | Washer Repair | 0 | 04-05-2008 07:12 PM |
