| » GE Washer won't agitate |
Model Number: wbse3120b1ww Brand: GE Age: 5 - 10 years
My washer will fill with water, drain, and spin. It will not agitate. We have taken the agitater off, but what do I do now? How can I tell what is broken and what I need to replace? Any guidance would be appreciated.
I took that part out and it appears to be fine. It sits over the large metal piece and it will go back and forth. The metal piece it sits on will not budge. Is that part of the transmission? If so, is that expensive? I ask because the machine is just under 10 years old and if this will be expensive I will look into buying a new one. If I need to call the repairman it will get expensive in a hurry.
Pull the agitator off, remove the front panel, and move the motor pulley ( one way agitate, the other spin) in the agitate direction. Have someone hold the plastic coupler. If it fails to turn back and forth, remove the coupler and check the tranny spline. If it moves back and forth, you have a stripped coupler, if not, a bad tranny.
__________________
| Display Modes | |
| Washer won't agitate | tboreman | Washer Repair | 0 | 10-27-2009 04:35 AM |
| stackable washer dryer: washer will not agitate | jennypatterson | Dryer Repair | 0 | 03-04-2009 11:08 AM |
| washer won't agitate | t1572 | Washer Repair | 4 | 11-22-2008 03:26 PM |
| washer hum/will not agitate | sv grant | Washer Repair | 2 | 10-27-2008 05:32 AM |
| Washer Will Not Agitate | TVJ | Washer Repair | 5 | 12-17-2007 10:14 AM |
