| » topload washer water problem |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Your drain pipe may be to short.This will cause the water to drain while it fills,also if it,s tape around the top of the drain pipe and the washers drain hose this also will cause the same problem.This problem is caused by the syphoning effect brought on by either gravity in the first case or by vacumn in the second case.Or there could be a problem in your pump the check valve may be bad causing the same problem...
__________________
| Display Modes | |
| water problem | chris1969 | Refrigerator & Freezer Repair | 0 | 05-03-2008 11:18 AM |
| Kenmore Washer gushing water from bottom, Can the pump be the problem? | fancinan@comcast.net | Washer Repair | 3 | 04-17-2008 08:34 AM |
| Water Problem | Strattus | Washer Repair | 0 | 02-26-2008 07:54 AM |
| Water dispenser problem | Noose | Refrigerator & Freezer Repair | 2 | 12-29-2007 12:45 PM |
| f&P topload degx1 screeching sound | cmayes71 | Dryer Repair | 0 | 10-02-2007 09:09 AM |
