Discuss
topload washer water problem
 in
Washer Repair
Water keeps running and drains out at the same time
Appliance Repair Forum > Appliance Repair Help > Washer Repair » topload washer water problem
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-10-2008, 04:07 AM
markcopelli markcopelli is offline
Junior Member
markcopelli is on a distinguished road
Default topload washer water problem
Brand: White-Westinghouse   Age: Less than 1 year
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-10-2008, 05:08 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
Your drain pipe may be to short.This will cause the water to drain while it fills,also if it,s tape around the top of the drain pipe and the washers drain hose this also will cause the same problem.This problem is caused by the syphoning effect brought on by either gravity in the first case or by vacumn in the second case.Or there could be a problem in your pump the check valve may be bad causing the same problem...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water problem chris1969 Refrigerator & Freezer Repair 0 05-03-2008 11:18 AM
Kenmore Washer gushing water from bottom, Can the pump be the problem? fancinan@comcast.net Washer Repair 3 04-17-2008 08:34 AM
Water Problem Strattus Washer Repair 0 02-26-2008 07:54 AM
Water dispenser problem Noose Refrigerator & Freezer Repair 2 12-29-2007 12:45 PM
f&P topload degx1 screeching sound cmayes71 Dryer Repair 0 10-02-2007 09:09 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
