I had flash code 4 to begin with, but the motor wouldn't move at all. so I replaced the motor and the mode shifter. It worked great for 2 loads of clothes and now it won't spin or agitate and I have the 4 flash code again. any suggestions?
That should have done it, so clear out the code,
To clear the error code, turn the washer off. Then disconnect power for about 20 seconds. Next, reconnect power then open and close the lid five or more times within 12 seconds in the first 30 seconds of power-up.
and see if that does not get it going. If not, you may have gotten a defective motor (which has the inverter built in).
and see if that does not get it going. If not, you may have gotten a defective motor (which has the inverter built in). I have tried to clear the error codes twice and have not been able to get the error code to clear. suggestions?
Return the motor to the supplier and ask for a replacement
