Discuss
washer fills, timer doesn't advance, nor does it agitate, spin, or drain
 in
Washer Repair
My washer will fill with water but after that it is silent, the timer doesn't advance, it doesn't
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer fills, timer doesn't advance, nor does it agitate, spin, or drain
  #1 (permalink)
Old 06-09-2008, 12:17 PM
threads68 threads68 is offline
Junior Member
threads68 is on a distinguished road
Unhappy washer fills, timer doesn't advance, nor does it agitate, spin, or drain
Model Number: VVXR1040T2WB   Brand: Hotpoint   Age: More than 10 years
My washer will fill with water but after that it is silent, the timer doesn't advance, it doesn't agitate, spin, or drain the water, what could be wrong with it? the machine is about 12 years old, I used to be able to "wiggle" the wires and make sure that everything was connected and that would fix the problem, this time I wasn't so lucky. Help!!!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-09-2008, 05:16 PM
Junior Member
Default washer problem
I have checked the lid switch continuity and the timer continuity, both are testing okay, what else could it be?????
  #3 (permalink)
Old 06-09-2008, 06:15 PM
Junior Member
Default
found the problem, after checking the continuity to the motor,which checked out fine, we pulled the circuit/control board, and it had a bad solder point on one of the pins, we resoldered the pin and the washer now works. thought someone might be interested in the outcome of this
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 2 01-29-2008 06:09 PM
Washer won't drain, fills while in spin mode darrinmcclure Washer Repair 2 01-18-2008 10:18 AM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 02:20 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
GE Washer Tank Fills but No Spin/Wash/Drain jrgreulich Washer Repair 3 09-02-2007 06:09 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
