Discuss
Water will not shut off
 in
Washer Repair
Last night out washer overflowed. We discovered that the water is not shutting off. THe spin cycle works and drains.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water will not shut off
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-09-2008, 09:46 AM
nvinyard nvinyard is offline
Junior Member
nvinyard is on a distinguished road
Smile Water will not shut off
Model Number: FWS445RF   Brand: Frigidaire   Age: 5 - 10 years
Last night out washer overflowed. We discovered that the water is not shutting off. THe spin cycle works and drains. What can cause this problem and how easy is it to fix?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-10-2008, 01:04 PM
JWLOAR2004 JWLOAR2004 is offline
Junior Member
JWLOAR2004 is on a distinguished road
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #3 (permalink)
Old 06-10-2008, 01:21 PM
Junior Member
Default
My husband raised the top of our washer and discovered a hose had come off. He replaced the hose and the problem is solved. It is had not been for this forum I would have never had an idea as to what the problem could have been.
  #4 (permalink)
Old 06-10-2008, 01:29 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
The hose nvinyard is refering to is the pressure switch hose, a clear rubber hose that goes from the pressure switch to the tub. If this hose is cut, clogged or disconnected from either spot the water will never shut off.
__________________
Who wants a chance to win $10,000 a week for the next 17 weeks? How about $250,000 if you have the most points after 17 weeks. The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water will not shut off nvinyard Washer Repair 0 06-09-2008 09:45 AM
Incoming Water Won't Shut Off SYLVANIA Washer Repair 11 06-05-2008 05:43 AM
Water won't shut off fordleonard Washer Repair 4 06-04-2008 07:56 PM
Water does not shut off VictorC Washer Repair 0 01-29-2008 05:25 PM
water will not shut off jim4032 Washer Repair 2 12-02-2007 02:34 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
