Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   GE stackable washer/dryer (http://forum.appliancepartspros.com/washer-repair/86753-ge-stackable-washer-dryer.html)
realistic 03-31-2010 11:06 AM
Hello,
My stackable washer/dryer only spins slow. It do not kick into final fast spin. I have replaced timer,motor&pump. I belive the trans is good beacause it dose spin and only the motor is 2 speed. This only leaves the clutch I think. If that is the case, what is the symptoms of a bad clutch? Or what could my promblem be?
thanks so much !!
Joe / APP Team 05-25-2011 07:16 AM
Quote:
Originally Posted by realistic (Post 203765)
Hello,
thanks so much !!
Realistic,
You're getting there, a slipping clutch or a dragging brake pad, could cause a slow spin,
Part number: AP2046416
Part number: AP2046398
as well as a bent, weak drive coupling, but that usually makes some sort of noise eventually.
The drive system on your washer is very similar to a different manufacturer's so this should help you out,
http://forum.appliancepartspros.com/...ake-shoes.html
Good Luck,
