Discuss
Maytag Atlantis washer spins but doesn't drain water
 in
Washer Repair
I can't get the model # of my Maytag Atlantis as it's filled with water. Hose isn't kinked or blocked.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Atlantis washer spins but doesn't drain water
  #1 (permalink)
Old 03-29-2010, 08:41 PM
Junior Member
ramchaza is on a distinguished road
Default Maytag Atlantis washer spins but doesn't drain water
Brand: Maytag   Age: 1 - 5 years
I can't get the model # of my Maytag Atlantis as it's filled with water. Hose isn't kinked or blocked. It will spin fine but the water doesn't drain out. Sometimes if I turn it back to spin it'll work but it's hit and miss.
How do I check the lid switch? I think I see that the little white thing in the lid switch isn't dropping down all the way as it moves down when I fiddle with it. Any way to theck it other than taking the top off the washer???
Help! It worked great for a few days when I got it home, bought it used and lady said she never had a problem with it!!!
thanks so much,
Theresa
Ads By Google
  #2 (permalink)
Old 03-30-2010, 08:28 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
You may have a restricted or blocked pump. First, try lifting the drain hose almost completely out of the drain stand pipe as it's spinning. If it starts to drain, you just had it too far into the pipe. If not, you can let the water siphon out by lowering the hose below the level of the water in the tub. It takes a little longer, but only costs you time. With the water out, you can then examine the machine for the cause of the problem. Let us know what you find. We can explain to you how to gain access to the inside of your machine, if needed.
  #3 (permalink)
Old 03-30-2010, 09:57 AM
Junior Member
Default
While fiddling around with it I saw that the place where the thing on the lid pushes into the thing on the washer to make it spin, well that little white thing wasn't dropping down all the way. I got a thin skewer and was able to make the little white switch thing drop down all the way.
So I think it's called the lid switch? Was able to get the water all drained out after I got the white thing that's attahed to the washer part to drop down.
Is there a way to fix that without thaking the whole thing apart? Or do I have to replace the entire lid switch? Any plain English directions would me most welcome!
thanks so much,
Theresa
  #4 (permalink)
Old 03-30-2010, 10:40 AM
Senior Expert
APP Volunteer
Default
What's the model number?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis top loading washer doesn't spin out water ramchaza Washer Repair 2 03-22-2010 09:47 AM
Maytag Atlantis Washer No Hot Or Warm Water jakemdr Washer Repair 5 03-07-2010 09:40 PM
Maytag Atlantis Won't Drain dkent59 Washer Repair 3 01-07-2010 03:29 AM
Amana washer spins but does not drain water out fjhead2000 Washer Repair 2 11-24-2007 08:44 AM
