| » Frigidaire F/Load Won't Spin or Agitate |
Model Number: FWT449GFS2 Brand: Frigidaire Age: 5 - 10 years
Frigidaire front load washer won't spin or agitate. I did the diagnosis from the tech sheet inside the washer and everything checked out fine except the last step, where it says if you get about 6 ohms it is the spin control board. I replaced the spin control board($220.00) last night and did 2 loads of laundry, no problem. Put another load in this morning and it won't agitate or spin. It pumps out water no problem, just will not agitate or spin. What should I try next. Thanks for your reply.
Related Models |
Recheck your connections on the board you replaced, could be a connection that worked loose.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
Retried the connections, same results, no spin or agitate. I went through all of the diagnosis steps again, the only test that was different was that I did not get the 6 ohm on the final test, it was 0. Is there any connections that are typically a problem with this model or is there more trouble-shooting you can help me with. I am pretty handy, but there are limits. At what point do I throw in the towel and either get a service person or get a new machine. Thanks for your reply.
| Display Modes | |
| Frigidaire front load washer will not spin | Merlis | Washer Repair | 10 | 10-05-2009 05:37 PM |
| Frigidaire F/Load Won't agitate or spin | dfran | Dishwasher Repair | 1 | 06-08-2008 10:12 AM |
| Frigidaire LCE702AWW2 won't spin or agitate | ZoesMom | Washer Repair | 0 | 01-23-2008 06:33 PM |
| Frigidaire Front Load Washer Won't Spin | bbemis | Washer Repair | 2 | 11-28-2007 08:46 AM |
| spin cycle on frigidaire front load | Mikki | Washer Repair | 2 | 10-08-2007 05:15 PM |
