Discuss
washer stops after water fills suspect timer
 in
Washer Repair
How do I remove the timer button on the machine? the water level button and temp button just pulled off.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops after water fills suspect timer
  #1 (permalink)
Old 06-04-2008, 02:30 PM
alpierro alpierro is offline
Junior Member
alpierro is on a distinguished road
Default washer stops after water fills suspect timer
Model Number: kawe560wwh3   Brand: Kitchen Aid   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-05-2008, 02:19 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your washer is a bad lid switch (#11 on the top & cabinet break down diagram), not the timer.
- The part number for the lid switch is AP3094500
Here are the break down diagrams for the Kitchen Aid washer Model KAWE560WWH3
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-07-2008, 07:58 AM
Junior Member
Default Thanks Gene for your reply!!!
My wife gave me more information on the problem, she says if she sets the water level to small or medium the washer completes the cycle and stops as normal. It is when she sets the water level to Large that it stops after it fills. Does that mean the water level switch is a problem??? Thanks again for your input. Have a great day!!!!
  #4 (permalink)
Old 06-07-2008, 06:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Set the water level to Large. Start the cycle.
If it would stop after it fills then unplug the washer, open the control panel, remove the "V' & "T" wires from the water level switch and check for continuity across "V" & "T" terminals on the water level switch. Replace the water level switch if it's open.
- The part number for the water level switch is AP2907096
__________________
  #5 (permalink)
Old 06-16-2008, 08:11 AM
Junior Member
Default Still not going into wash cycle
I checked continuity on the V and T terminals on the water level switch and get good continuity. Since that was good I went and checked the lid switch for a short when actuated and I get a good short. Today we filled the machine and found that the timer advances through all the cycles. However as before it does not agitate but does rinse and spin. Does the motor have a separate winding for agitate and one for spin ? Could this mean the moter is bad for wash/agitate only? Do you have any other suggestions?
Last edited by alpierro : 06-16-2008 at 10:53 AM. Reason: Some additional information about symtoms
  #6 (permalink)
Old 06-16-2008, 04:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not see how a problem with the motor or the timer could be connected to water level, especially if there is nothing wrong with the water level switch. Did your wife used the same wash cycle when it happened or she used different cycles?
P.S. Here is the wiring diagram for your washer.
__________________
  #7 (permalink)
Old 06-16-2008, 06:43 PM
Junior Member
Default Thanks again Gene for your reply!!
The machine is not going into the wash cycle at any water level now. When I reported that it worked at the medium water level I think what happened was my wife left the machine after it started to fill. Since the timer advanced it eventually went into the rest of the cycles and since it rinsed and went through the spin and then to off it looked like it worked. In any case it fills, the timer advances but it does not agitate but does all other functions. At the agitate duration of the timer I did not hear anything other than the timer advancing. The motor didn't make any noise during that agitate cycle.
I noticed on another response you made to the same problem you mentioned the agitator dog was the problem. My agitator top spins freely in both directions and so does the agitator bottom. Does that mean the Agitator Dogs are bad in my machine?
If the above isn't the problem do I need to check the motor. do I check for continuity at the Low winding between V and W-Bk?
  #8 (permalink)
Old 06-16-2008, 08:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I would remove the cabinet and check the motor plug and all wires to the motor. If there is nothing wrong then the problem, most likely, is a bad timer.
__________________
  #9 (permalink)
Old 06-18-2008, 01:04 AM
Junior Member
Default Thanks Gene Very Much!!!!
I will check the motor plug as you suggest. If ok I will replace the timer.
  #10 (permalink)
Old 06-18-2008, 01:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer fills with water by itself michele1234 Washer Repair 3 04-02-2008 08:10 PM
Maytag Washer fills then stops Tazman Washer Repair 4 01-23-2008 01:44 PM
Fills and stops metten2@verizon.net Washer Repair 9 01-08-2008 02:57 PM
water fills and stops intermittently worldtravelert Washer Repair 0 12-08-2007 10:50 AM
washer fills with water then run program cancels Doug Quinn Washer Repair 0 11-03-2007 09:39 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
