| » washer will not transition from agitate to drain & rinse |
Model Number: LSQ8543JQ0 Brand: Whirlpool Age: 1 - 5 years
This Whirlpool washer fill & agitates fine, but when it stops and should move forward to drain & rinse it kind of makes a ticking sound but won't start the next step. It doesn't matter if you are doing large heavy loads or perm presss or deligate. it seems to do the same thing no matter what the type of load. I ordered and replaced the timer, but it still does the same thing. What should I check next??
MSR |
I have a Whirlpool model WTW5800SW and it is doing the same thing. I made sure the pump was clear and rotating smoothly, checked the lid switch and replaced the motor and capacator (this was recommended by ************.com). It still does not drain after the adgitation cycle. Any suggestions?
| Display Modes | |
| Washer stops at Rinse Cycle and doesn't drain water | kukoch | Washer Repair | 5 | 06-04-2008 01:44 AM |
| Washer won't agitate or spin after rinse cycle | tickytutt | Washer Repair | 1 | 03-11-2008 11:31 AM |
| Washer will fill, drain, spin but won't agitate | tmatsick | Washer Repair | 2 | 01-29-2008 06:09 PM |
| Washer won't drain/spin in rinse cylce | jimII | Washer Repair | 2 | 01-15-2008 12:30 AM |
| Washer will fill and agitate but not spin/drain at all | Narapni | Washer Repair | 0 | 11-03-2007 02:20 AM |
