Discuss
Washer Advances But...
 in
Washer Repair
3-4 Times For The Past Week My Washer Has Stopped At The Spin/drain Cycle And Now Has Completely
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Advances But...
  #1 (permalink)
Old 07-22-2007, 06:04 PM
CAN I DO IT CAN I DO IT is offline
Junior Member
CAN I DO IT is on a distinguished road
Question Washer Advances But...
Model Number: 11092429800   Brand: Kenmore   Age: More than 10 years
3-4 Times For The Past Week My Washer Has Stopped At The Spin/drain Cycle And Now Has Completely Stopped At This Cycle. The Knob Advances To The Spin Mark But Doesn't Do Anything Else(Doesn't Spin/Doesn't Drain), And It Sounds Dead, No Sound At All. Can This Be The Lid Switch? My Grandson Has Slammed Down The Lid Several Times In The Past 2 Weeks! Or Am I Most Likely Looking At A Problem With The Timer? Also, Can This Be A "Do It Yourself" Job?
(FR: dhvillasana2u@aol.com)
Related Models
Kenmore 11092572100 WASHER
Kenmore 11092572800 WASHER
Kenmore 11092573010 WASHER
Kenmore 11092573110 AUTOMATIC WASHER
Kenmore 11092573810 AUTOMATIC WASHER
Kenmore 11092573910 WASHER
Kenmore 11092580000 AUTOMATIC WASHER
Kenmore 11092580900 AUTOMATIC WASHER
Kenmore 11092581120 AUTOMATIC WASHER
Kenmore 11092581220 AUTOMATIC WASHER
Kenmore 11092581420 AUTOMATIC WASHER
Kenmore 11092581820 AUTOMATIC WASHER
Kenmore 11092582100 AUTOMATIC WASHER
Kenmore 11092582120 AUTOMATIC WASHER
Kenmore 11092582420 AUTOMATIC WASHER
Kenmore 11092582800 AUTOMATIC WASHER
Kenmore 11092582820 AUTOMATIC WASHER
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11095 CEILING FAN
Kenmore 11096195120 ELECTRIC DRYER
Kenmore 11096195500 ELECTRIC DRYER
Kenmore 11096195510 DRYER FEATURE SHEET
Kenmore 11096195520 ELECTRIC DRYER
Kenmore 11096195800 ELECTRIC DRYER
Kenmore 11096195810 DRYER FEATURE SHEET
Kenmore 11096195820 ELECTRIC DRYER
Kenmore 11096210100 DRYER-FEATURE SHEET
Kenmore 11096220100 DRYER-FEATURE SHEET
Kenmore 11096250100 DRYER-FEATURE SHEET
Kenmore 11096260100 DRYER FEATURE SHEET
Kenmore 11096263100 DRYER-FEATURE SHEET
Kenmore 11096263800 DRYER-FEATURE SHEET
Kenmore 11096264100 DRYER FEATURE SHEET
Kenmore 11096264800 DRYER FEATURE SHEET
Kenmore 11096271100 DRYER FEATURE SHEET
Kenmore 11096271600 DRYER FEATURE SHEET
Kenmore 11096271800 DRYER FEATURE SHEET
Kenmore 11096272000 ELECTRIC DRYER
Kenmore 11096272100 DRYER FEATURE SHEET
Kenmore 11096272600 DRYER FEATURE SHEET
Kenmore 11097091100 GAS DRYER
Kenmore 11097091300 GAS DRYER
Kenmore 11097091700 GAS DRYER
Kenmore 11097091800 GAS DRYER
Kenmore 11097093100 GAS DRYER
Kenmore 11097093300 GAS DRYER
Kenmore 11097093500 GAS DRYER
Kenmore 11097093700 GAS DRYER
Kenmore 11097093800 GAS DRYER
Kenmore 11097094100 GAS DRYER
Kenmore 11097094300 GAS DRYER
Kenmore 11097094500 GAS DRYER
Kenmore 11097094700 GAS DRYER
Kenmore 11097094800 GAS DRYER
Kenmore 11097195100 GAS DRYER
Kenmore 11097195110 DRYER FEATURE SHEET
Kenmore 11097195120 GAS DRYER
Kenmore 11097195500 GAS DRYER
Kenmore 11097195510 DRYER FEATURE SHEET
Kenmore 11097195520 GAS DRYER
Kenmore 11097195800 GAS DRYER
Kenmore 11097195810 DRYER FEATURE SHEET
Kenmore 11097195820 GAS DRYER
Kenmore 11097210100 DRYER-FEATURE SHEET
Kenmore 11097220100 DRYER-FEATURE SHEET
Kenmore 11097250100 DRYER-FEATURE SHEET
Kenmore 11097260100 DRYER FEATURE SHEET
Kenmore 11097264100 DRYER FEATURE SHEET
Kenmore 11097264800 DRYER FEATURE SHEET
Kenmore 11097271100 DRYER FEATURE SHEET
Kenmore 11097271600 DRYER FEATURE SHEET
Kenmore 11097271800 DRYER FEATURE SHEET
Kenmore 11097272100 DRYER FEATURE SHEET
Kenmore 11097272600 DRYER FEATURE SHEET
Kenmore 11097272800 DRYER SPECIFICATIONS
Kenmore 11097273100 DRYER FEATURE SHEET
Kenmore 11097273600 DRYER FEATURE SHEET
Kenmore 11097273800 DRYER FEATURE SHEET
Kenmore 11097274100 DRYER FEATURE SHEET
Kenmore 11097274600 DRYER FEATURE SHEET
Kenmore 11097274800 DRYER FEATURE SHEET
Kenmore 11097278100 DRYER FEATURE SHEET
Kenmore 11097278800 DRYER FEATURE SHEET
Kenmore 11097280100 DRYER FEATURE SHEET
Kenmore 110985000 SEARS DIRECT DISCHARGE WALL FAN
Kenmore 110985100 VERTICAL DISCHARGE FAN
Kenmore 11098518200 ELECTRIC DRYER
Last edited by CAN I DO IT : 07-24-2007 at 05:48 PM. Reason: rephrasing & adding contact info.
  #2 (permalink)
Old 07-26-2007, 01:31 PM
Adam / APP Team Adam / APP Team is offline
Administrator
APP Team
Adam / APP Team is on a distinguished road
Default
Dear CAN I DO IT,
It sounds like a bad lid switch. You might also check the strike on the lid. It could be missing or cracked .
Check the lid switch for continuity with your meter. It should alternate between having and not having continuity when you depress the lever, also check the switch for damage some newer styles have a history of cracking in half.
The lid switch is not too difficult to change. The best and easiest way to change it is to remove the cabinet.
Click here to go to RepairAve.com to see how to remove the cabinet
  #3 (permalink)
Old 07-26-2007, 03:23 PM
Junior Member
Smile Thank You "ADAM"
Thank You So Much For The Feed Back And Quick Response. Also For The Link To Taking The Washer Apart. I Haven't Checked The Part Yet, But Am On My Way. Again, Thanks Very, Very Much!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
