| » Water won't shut off |
Model Number: WJSR2080T2AA Brand: GE Age: More than 10 years
About once every 3 months, the rinse water will keep running until I manually advance the timer forward. If I don't catch it, the water will run for hours and not shut off.
Sounds like a pressure switch problem, not necessarily the switch itself, could be the pressure switch hose. Remove the front cover of the machine, and to the left of the tub is where the tube connects to the air chamber. remove the tube, and look to see if it is discolored. cut off the discolored part, now get yourself something small to stick down the nipple the hose came off to clean it out, put hose back on, put washer in the largest wash and watch it fill. the water should go no higher than the last holes in the basket. Post the results when finished. This will happen if you don't use bleach to often
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
I checked the hose on the pressure switch and didn't see any blockage. I went ahead and cut off end of hose and reattached after cleaning out nipple in switch. Is there any other thing that might cause this?
If it is clogged, it will be clogged at the tub, not the pressure switch, take the front of the machine off, it's on the left side. let me know if you don't know how to remove the front
__________________
Where I checked for restriction was down on the tub which I was calling the pressure switch (it's a plastic piece mounted to the tub behind the front cover of the washer. Could the problem have anything to do with the timer switch? When the problem occurs you can advance the timer one click and it starts working again, which is not a big problem except the water will run for hours and the timere stays in the rinse cycle if its not caught and can run up the water bill. The water does not overflow the tub but exists out through the drain hose.
| Display Modes | |
| Incoming Water Won't Shut Off | SYLVANIA | Washer Repair | 11 | 06-05-2008 06:43 AM |
| Incoming Water Won't Shut Off | SYLVANIA | Washer Repair | 0 | 05-30-2008 09:05 AM |
| Ice maker water won't shut off | karnack | Refrigerator & Freezer Repair | 1 | 05-11-2008 06:10 PM |
| Water does not shut off | VictorC | Washer Repair | 0 | 01-29-2008 06:25 PM |
| water will not shut off | jim4032 | Washer Repair | 2 | 12-02-2007 03:34 PM |
