| » Cold water connection |
Model Number: WFMC3200UC/01/FD8412/902969 Brand: Bosch Age: 1 - 5 years
I was having some problems with the washer not draining properly so I pulled it out cleaned out the water drainage hose and figured while I had the heavy thing out I should clean the strainers on the cold and hot water inlet hoses. While trying to pull out the strainer I messed up the tip of the threads to the water connection on the back of the washer. I used a utility knife and metal file to take of the messed up tip and now seem to have a very small leak ( putting a paper towel around hose during a cycle it is slightly damp). What should I do now. Can the male connector on the back of the machine be re-placed?
| Display Modes | |
| washer spewing water at connection to pump | Julitx | Washer Repair | 1 | 02-24-2010 12:00 PM |
| Leaky Connection: Plastic tubing to Water Inlet Valve | tdreid | Refrigerator & Freezer Repair | 1 | 01-21-2010 04:16 AM |
| dual water valve connection | colehg | Refrigerator & Freezer Repair | 0 | 08-09-2009 06:53 AM |
| Hose connection to Water Valve | wirelessrulz | Refrigerator & Freezer Repair | 1 | 12-29-2008 03:35 PM |
