Discuss
GE Washer will not drain or spin
 in
Washer Repair
Put in new timer and it''s doing the samething.I turn it on and it went thru all the way just
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer will not drain or spin
  #1 (permalink)
Old 06-02-2008, 04:48 PM
Junior Member
myzippo27 is on a distinguished road
Default GE Washer will not drain or spin
Model Number: WJSR2070B9WW   Brand: GE   Age: 1 - 5 years
Put in new timer and it''s doing the samething.I turn it on and it went thru all the way just find.So I put a small load in and it went thru all the cycles and where it should have stop, well it didn't.It just kept going.So I stop it and turn it to rinse and drain and all I hear is a motor running.It wont drain at all. And it wont spin either.I check the lid switch and it works on the other cycles.Also,on the old timer,if I unplug the washer over night the next day it would do one load fine and then as I describe above.
Related Models
General Electric WJSR2070B9WW WASHER
General Electric WJSR2070D0WW Washer
General Electric WJSR2070D1WW Washer
General Electric WJSR2070D2WW Washer
General Electric WJSR2070D3WW Washer
General Electric WJSR2070D5WW Washer
General Electric WJSR2070D6WW Washer
General Electric WJSR2080T2AA Washer
General Electric WJSR2080T2WB Washer
General Electric WJSR2080T2WW Washer
General Electric WJSR2080T3AA Washer
General Electric WJSR2080T3WB Washer
General Electric WJSR2080T3WW Washer
General Electric WJSR2080T5AA Washer
General Electric WJSR2080T5WB Washer
General Electric WJSR2080T5WW Washer
General Electric WJSR2080T6AA Washer
General Electric WJSR2080T6WB Washer
General Electric WJSR2080T6WW Washer
General Electric WJSR2080T8AA Washer
General Electric WJSR2080T8WB Washer
General Electric WJSR2080T8WW Washer
General Electric WJSR2080TAAA Washer
General Electric WJSR2080TAWB Washer
General Electric WJSR2080TAWW Washer
General Electric WJSR2080V1AA Washer
General Electric WJSR2080V1WW Washer
General Electric WJSR2080V2AA Washer
General Electric WJSR2080V2WW Washer
General Electric WJSR2080V3AA Washer
General Electric WJSR2080V3WW Washer
General Electric WJSR4160D0CC Washer
General Electric WJSR4160D0WW Washer
General Electric WJSR4160D2CC Washer
General Electric WJSR4160D2WW Washer
General Electric WJSR4160D5CC Washer
General Electric WJSR4160D5WW Washer
General Electric WJSR4160D6CC Washer
General Electric WJSR4160D6WW Washer
General Electric WJSR4160DACC Washer
General Electric WJSR4160DAWW Washer
General Electric WJSR4160DCCC Washer
General Electric WJSR4160DCWW Washer
General Electric WJSR4160G0WW Washer
General Electric WJSR4160G1WW WASHER
General Electric WJSR4160G2WW WASHER
General Electric WJSR4160G3WW WASHER
General Electric WJSR4160G4WW WASHER
General Electric WJSR4160G5WW WASHER
General Electric WJSR4160G6WW WASHER
General Electric WJXR2080T2AA Washer
General Electric WJXR2080T2WW Washer
General Electric WJXR2080T3AA Washer
General Electric WJXR2080T3WW Washer
General Electric WJXR2080T5AA Washer
General Electric WJXR2080T5WW Washer
General Electric WJXR2080T6AA Washer
General Electric WJXR2080T6WW Washer
General Electric WJXR2080T8AA Washer
General Electric WJXR2080T8WW Washer
General Electric WJXR2080TAAA Washer
General Electric WJXR2080TAWW Washer
General Electric WJXR2080V0AA Washer
General Electric WJXR2080V0WW Washer
Whirlpool WKP85800 30" ELECTRIC RANGE CERAN COOKTOP
General Electric WKRE5500K0WW WASHER
General Electric WKRE5550K0WW WASHER
General Electric WKRE6280D0WW Washer
General Electric WKRE6280D1WW Washer
General Electric WKRE6280DCWW Washer
General Electric WKSE5260E0WW Washer
General Electric WKSE5260E1WW Washer
General Electric WKSE5260E6WW Washer
General Electric WKSE6280B1WW Washer
General Electric WKSE6280B2WW Washer
General Electric WKSE6280B3WW Washer
General Electric WKSR2100T2AA Washer
General Electric WKSR2100T2WW Washer
General Electric WKSR2100T3AA Washer
General Electric WKSR2100T3WW Washer
General Electric WKSR2100T5AA Washer
General Electric WKSR2100T5WW Washer
General Electric WKSR2100T6AA Washer
General Electric WKSR2100T6WW Washer
General Electric WKSR2100T8AA Washer
General Electric WKSR2100T8WW Washer
General Electric WKSR2100T9AA Washer
General Electric WKSR2100T9WW Washer
General Electric WKSR2100TAAA Washer
General Electric WKSR2100TAWW Washer
General Electric WKSR2100TBAA Washer
General Electric WKSR2100TBWW Washer
General Electric WKSR2100TCAA Washer
General Electric WKSR2100TCWW Washer
Amana WKU-617 RANGE- S/C S/I DDRAFT GAS
Amana WKU-617A RANGE- S/C S/I DDRAFT GAS
General Electric WKXR2100T2AA Washer
General Electric WKXR2100T2WW Washer
General Electric WKXR2100T3AA Washer
General Electric WKXR2100T3WW Washer
General Electric WKXR2100T5AA Washer
General Electric WKXR2100T5WW Washer
General Electric WKXR2100T6AA Washer
General Electric WKXR2100T6WW Washer
General Electric WKXR2100T8AA Washer
General Electric WKXR2100T8WW Washer
General Electric WKXR2100TAAA Washer
General Electric WKXR2100TAWW Washer
General Electric WKXR2100TBAA Washer
General Electric WKXR2100TBWW Washer
Frigidaire WL24F2WWMA Gib(v1) / 24 " Laundry Center
Frigidaire WL24F2WWMB Gib(v1) / 24 " Laundry Center
Frigidaire WL24F2WYMA Gib(v1) / 24 " Laundry Center
Frigidaire WL24F2WYMB Gib(v1) / 24 " Laundry Center
Frigidaire WL24F2WYMC Gib(v1) / 24 " Laundry Center
Frigidaire WL24F4WWMA Gib(v1) / Laundry Center
Frigidaire WL24F4WWMB Gib(v1) / Laundry Center
Frigidaire WL24F4WYMA Gib(v1) / 24 " Laundry Center
Frigidaire WL24F4WYMB Gib(v1) / 24 " Laundry Center
Frigidaire WL24F4WYMC Gib(v1) / 24 " Laundry Center
  #2 (permalink)
Old 06-02-2008, 05:43 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
I would check the drain pump for a clog. Remove the front panel of the washer, the pump is at the front bottom right side, with 2 hoses attached. Now either get the water out of the tub with a shop vac, or pinch off the hose connecting the tub to the drain pump. Take the top hose off, and stick your finger down the hole and feel for anything. also you can stick a screw driver down the pump and see if the impeller moves freely...Post your findings
__________________
  #3 (permalink)
Old 06-27-2008, 08:03 AM
Junior Member
Default
Sorry For Taking So Long ,,,i Tried That And It Seem To Me That The Impeller Is Made Of Rubber And It Wouldn't Move.we Put A Load In Last Night,the First Load Did Great.the Second Load ,the Timer Went Around Twice Before We Turned It Off. The Third Load Stop At The Rinse And Spin Cycle,it Sounds Like A Motor Is Running But There Is Notting Going On.so We Turned It Off For About An Hour.i Left It In The Same Postion That It Had Stop On,so I Just Pulled The Knob To Turn It On And It Drain An Spun Like New....we Go Thru This Every Time. HOW DO I BYPASS THE LID SWITCH????
  #4 (permalink)
Old 06-27-2008, 02:55 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
With the front panel removed, remove the two 1/4inch screws facing you that hold the top panel. now lift up on the top and pull twards you. You will see a 2 pin connector, disconnect that, that is your lid switch harness. You can bypass it there. Check to make sure the plunger on the lid is making the switch engage. Sometimes the wire that holds the bumper can get moved a bit.
__________________
  #5 (permalink)
Old 06-27-2008, 02:58 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
The impeller is plastic, and should move, if it wont move, or you hear a hum when it should be draining, I would suspect the pump is bad, or there is something in it getting caught.
__________________
  #6 (permalink)
Old 04-12-2012, 11:04 PM
Junior Member
lvnpink1976 is on a distinguished road
Default
Thanks drain pump was clogged
  #7 (permalink)
Old 04-12-2012, 11:05 PM
Junior Member
Default
thanks, good luck with water
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer won't drain and spin caullfieldj Washer Repair 1 03-30-2009 04:39 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
washer will not spin or drain Martha Shelby Washer Repair 2 10-25-2007 02:43 AM
washer will not spin or drain Martha Shelby Washer Repair 1 10-24-2007 03:59 AM
Washer won't drain or spin carrol Washer Repair 2 08-20-2007 06:37 AM
