| » Washer stops at Rinse Cycle and doesn't drain water |
The lid switch is definitely bad and has to be replaced without any additional tests. Hopefully the new lid switch will fix all problems.
- The lid switch Part number: 3949247 Gene. Ads By Google
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I have replaced the lid switch, and my washer is working fine again. After removing the cabinet, I did not remove the switch because I was looking for information on how to bypass the lid switch after unplugging it. When I removed the lid switch from the cabinet, I noticed it was cracked, probably from years of banging the lid on the switch
I'm glad to hear it's up and running. Hopefully with such training
__________________
| Display Modes | |
| Stops on rinse cycle, won't drain | BigPete | Washer Repair | 1 | 10-28-2009 12:02 PM |
| Only on rinse cycle washer won't fill up with water, goes right to the drain hose | pmmcadams | Washer Repair | 1 | 08-10-2009 03:33 PM |
| GE dishwasher, water will not drain after rinse cycle..... | FDAR | Dishwasher Repair | 3 | 07-29-2009 07:57 AM |
| Need HELP! Water will not drain after rinse cycle | coxcox2u | Washer Repair | 2 | 04-14-2009 06:45 PM |
| Problem- Washer stops at rinse cycle | zamana | Washer Repair | 1 | 01-25-2009 07:19 PM |
