:(Washer has been good to me, it's not producing hot water for the hot water cycles that I need. Any help will, be appreciated. Pam;)
Check to see if power is getting to the hot water valve on the water valves. If so, replaced the valve assembly.
If you need more assistance please post a full model number and the results of checking the valve.
