I have a 60 day old Maytag Centennial toploader. All of a sudden it's not filling. There is power; the water is on; the hose filters are clean; and I have waited patiently for it to start.
Kind of seems like the timer is seriously confused, maybe.
Any thoughts?
Dave H.
Call Maytag, you should still be under Factory Warranty on the machine.
I found a tech's manual on the inside front wall of the washer that directed me (pretty sneaky Maytag.) Found answer on page 7.
check: is water supply on, water pressure problem, drain hose not too deep (was my problem,) is water siphoning out of drain hose, check pressure hose connection from tub to pressure sensor (pinched, kinked, plugged, leaking air.) Diagrams in back of book.
Hope this helps someone :cool:
Groups: Expert
