| » Whirlpool Thin Twin Suspension Assembly |
Model Number: LTE5243DQ6 Brand: Whirlpool Age: 1 - 5 years
Frustrated... need assistance/ideas on how to remove the old suspension assembly from base - looks like they are welded or something. When rotated they just spin but don't unscrew.
Received parts and followed instructions included in box, however they just say to remove them and don't specify how to do so. New suspension assembly tells has additional screws to install to make suspension springs tight. Any help would be appreciated. Thank you. Ads By Google Related Models |
The "shock absorber" so to speak is basically a 2 part system. Since you are going to replace them anyway, use vice grips to grab the shaft (steel rod) and turn it out of the "welded nut" on the base. same with the other end. You may have to unscrew the other end Longer shaft) first to get to the base attachment.
| Display Modes | |
| Whirlpool Thin Twin W/D leaking from bottom | scottybab | Washer Repair | 1 | 09-28-2009 11:31 AM |
| leaking whirlpool thin twin washer | trevorroehl | Washer Repair | 1 | 09-06-2009 05:21 PM |
| Whirlpool Thin Twin Issue | Bobbipie | Washer Repair | 1 | 08-17-2009 10:38 AM |
| Whirlpool thin twin timer | DrDigital | Washer Repair | 2 | 08-03-2009 01:53 PM |
| Whirlpool Thin Twin Washer Problem | mineolabauer | Dryer Repair | 1 | 12-01-2008 08:45 AM |
