Discuss
Incoming Water Won't Shut Off
 in
Washer Repair
Water Does Not Shut Off When Entering Machine And Does Not Agitate. But Will Spin Out, Help
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Incoming Water Won't Shut Off
  #1 (permalink)
Old 05-30-2008, 09:12 AM
SYLVANIA SYLVANIA is offline
Junior Member
SYLVANIA is on a distinguished road
Default Incoming Water Won't Shut Off
Model Number: 41798702891   Brand: Kenmore   Age: 1 - 5 years
Help
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-30-2008, 09:18 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Does water enter when the machine is off or unplugged?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 05-30-2008, 09:24 AM
Junior Member
Default
No. Just When I Pull Knob Out To Fill.
  #4 (permalink)
Old 05-30-2008, 09:26 AM
Junior Member
Default
Quote:
NO.JUST WHEN I PULL OUT KNOB TO TURN ON
  #5 (permalink)
Old 05-30-2008, 09:37 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
So if you turned it on a regular wash and walked away, it would overfill the tub? If that is the case it is going to be a problem with either the presure switch or the hose to the pressure switch. Do you use bleach regularly, also I need a model#...
__________________
  #6 (permalink)
Old 05-30-2008, 09:46 AM
Junior Member
Default
No I Don't Use Bleach Too Often The Model# 41798702891
  #7 (permalink)
Old 05-30-2008, 10:10 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Because you don't use bleach regularly, I am suspecting that the end of the pressure switch hose is clogged where it connects to the tub... The model# you gave is not a model# for your machine, There will be a sticker with model# and serial#, usually if you open the lid it is there, maybe on the side panel of the machine
__________________
  #8 (permalink)
Old 05-30-2008, 10:46 AM
Junior Member
Default
This Is The Part Number On Both Machine And Paperwork For My Kenmore Laundry Center.
What Do I Do To Unstop This Hose End??
IS THIS ALSO WHY IT WON'T AGITATE?
ANY HELP WOULD BE APPRECIATED,.
  #9 (permalink)
Old 05-30-2008, 10:53 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
On the front bottom of the machine, there should be 2 screws at the bottom, you'll need to take that front cover off. the hose will be a small clear hose attached to a nipple on the outer tub. pull the hose off the tub and look for brown color at the end of the hose. let me know what you find
__________________
  #10 (permalink)
Old 05-31-2008, 07:00 AM
Junior Member
Default
I will let you know ASAP waiting for my son to get home from work to do as you suggested. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Incoming Water Won't Shut Off SYLVANIA Washer Repair 0 05-30-2008 09:05 AM
Ice maker water won't shut off karnack Refrigerator & Freezer Repair 1 05-11-2008 06:10 PM
water dispencer wont shut off tazman48169 Refrigerator & Freezer Repair 0 03-11-2008 03:29 PM
Water does not shut off VictorC Washer Repair 0 01-29-2008 06:25 PM
water will not shut off jim4032 Washer Repair 2 12-02-2007 03:34 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
