Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Maytag problem PLEASE HELP!! (http://forum.appliancepartspros.com/washer-repair/83974-maytag-problem-please-help.html)
sherrill28 03-17-2010 06:18 PM
My washer will fill but after it fills it wont agitaite, I can here the timer clicking but nothing. If I turn the timer to the next cycle it will spin. Sometimes after if fills it will shut off... I have to unplug it to reset then turn knob to next cycle and then it will start to drain and spin? I know it's not the timer, any ideas what's wrong? All belts appear to be fine.
Please give me some ideas, I appreciate it!
magician59 03-17-2010 08:40 PM
Have you tried it in the other wash cycles?
sherrill28 03-18-2010 07:31 PM
all other cycles seem to be working fine....the base of the agitaiter wont turn but the middle(top part turns) any ideas?
magician59 03-19-2010 09:48 AM
I'm inclined to say it sounds like a stripped agitator. With nothing in the machine, can you grasp the agitator base and turn it by hand?
sherrill28 03-20-2010 11:08 AM
no I can not turn it by hand, if its a stripped agitaiter how will I be able to tell? Is it expensive to fix?
magician59 03-20-2010 03:18 PM
If it were stripped, you would be able to turn it by hand. Since you're certain it's not the timer, it sounds like a transmission problem.
