Is it normal for this machines' water pump to be noisy enough to be heard 2-3 rooms away???
No. Before writing the pump off, though, inspect it to see if there's any foriegn matter in it. Also inspect the check valve (flapper) in it to see if a coin might be keeping it from fully opening. Here's the part numer. Part number: AP4035317
