Discuss
Kenmore/whirlpool spin tube thrust washer
 in
Washer Repair
Which way does the spin tube thrust washer face? (AP2905330)There is a tab on it, does it face towards
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore/whirlpool spin tube thrust washer
  #1 (permalink)
Old 05-29-2008, 10:50 AM
rjezuit rjezuit is offline
Junior Member
rjezuit is on a distinguished road
Default Kenmore/whirlpool spin tube thrust washer
Model Number: 110.26912691   Brand: Kenmore   Age: 5 - 10 years
Which way does the spin tube thrust washer face? (AP2905330)There is a tab on it, does it face towards the transmission or drum? What purpose does it serve? Thanks, Rick
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-29-2008, 11:49 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
That's really the spindle washer, goes on the tranny shaft to cover the c clip, recessed side towards tranny.
__________________
  #3 (permalink)
Old 05-29-2008, 04:17 PM
Junior Member
Default
I took the tranny apart, and looked around inside, nothing seems worn or broken at first glance, but it makes a ratcheting or clicking noise during the spin cycle, and the agitator turns a little during spin. If I lift up or grab the agitator the noise stops. It is easy to stop the agitator during the spin. This happens with the tranny out or in the machine with the agitator on. I also just put in a neutral drain kit that did not help. Any suggestions? Thanks, Rick
  #4 (permalink)
Old 05-30-2008, 04:31 AM
Senior Expert
APP Volunteer
Default
If you filled the tranny with oil, it probably is OK. I have seen this problem before and it really should not be a problem.
__________________
  #5 (permalink)
Old 05-30-2008, 10:30 AM
Junior Member
Default
The tranny is filled with oil, but it is now spinning slow???
  #6 (permalink)
Old 05-30-2008, 11:17 AM
Senior Expert
APP Volunteer
Default
Either your motor is smoking, or you have a bad clutch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Agitator repair kit thrust washer grease Imbobman Washer Repair 1 06-03-2008 09:58 AM
Washer won't spin at full speed, replaced thrust assy WasherGuy Washer Repair 4 05-27-2008 02:23 PM
Kenmore washer won't spin leon russell Washer Repair 1 03-13-2008 11:55 AM
Whirlpool washer won't spin whirlpoolblues Washer Repair 2 02-07-2008 04:32 PM
My 13 Year Old Kenmore Washer Aggitates But Does Not Spin GR8DAD Washer Repair 1 09-23-2007 10:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
