Discuss
GE front loader door boot replacement
 in
Washer Repair
I need to replace the door boot on this. Looks routine, but never did it before. Looks like I'll have
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE front loader door boot replacement
  #1 (permalink)
Old 03-16-2010, 01:22 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default GE front loader door boot replacement
Brand: GE   Age: 1 - 5 years
Looks like I'll have to remove the front counterweight. Any help would be appreciated.
Also, the bearings are starting to go bad on this, but that I don't want to do, too expensive.
Ads By Google
__________________
  #2 (permalink)
Old 03-16-2010, 02:38 PM
Senior Expert
APP Volunteer
Default
Ok no problem, downloaded the tech guide for the WBVh6240, looks the same. For this job, you have to remove the front panel and control panel, looks relatively easy.
End of problem
__________________
  #3 (permalink)
Old 03-19-2010, 05:09 PM
Senior Expert
APP Volunteer
Default
Update: It took more than two hours and sore fingers to get the boot on, had to remove both front weights and remove opper frame member, all not mentioned in the repair proceedure.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Door Boot Gasket - GE Chrisinomaha Washer Repair 53 08-31-2011 11:55 AM
ge door boot replacement instructions cbhman Washer Repair 3 04-20-2011 05:58 PM
replacin boot on g.e front loader old style misterfixall Washer Repair 3 12-04-2008 04:12 PM
how to install door boot on front load washer suzette Washer Repair 1 09-11-2008 10:23 AM
Frigidaire front-loader boot re-attachment trevorwallen Washer Repair 1 06-06-2008 01:20 PM
